20 Most Recent Samsung Galaxy Gio GT-S5660 Unlocked Quad-Band GSM Android Smartphone Questions & Answers
CHERRY MOBILE SNAP PATTERN UNLOCK
try this Let's start with the most common Hard Reset methods and go from there: Note: the different types of methods are numbered, method 1, method 2, method 3, etc. 1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it. 2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection. 3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key. Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time. If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it. Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it. 4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key). From the Android Recovery screen, press the Search key. Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select. Select Yes - delete all user data, and then select OK (again lower left). Select "reboot system now" and press OK. 5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc. With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time. When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key. Continue holding the Volume up and Home key until the "Android system recovery" screen appears. Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection. Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean. 6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS... While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step). A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key. Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up. Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK. After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK. Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen. 7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS. Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit. The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode. Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up. Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection. After it's done make sure "reboot system now" is highlighted and then tap the Power button. In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through. 8. Here is a hard reset for a Sharp Android Smartphone. While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously. Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection. Scroll down to Yes - delete all user data and then press the Power key to confirm. Once it is done select reboot system now and press the Power key to confirm and reboot your handset. enjoy
7/4/2014 9:38:02 AM • Samsung Galaxy... • Answered on Jul 04, 2014
HOW TO UNLUCK TOO MANUY PATERN ATTEMPTS
Type 5 times your wrong pattern , then type >>forgot your pattern>> , after that , confirm your email and password that you had registered in Google Play Store. #NZ
7/4/2014 9:16:29 AM • Samsung Galaxy... • Answered on Jul 04, 2014
Reset android quad band
have you tryed a factory reset? that should do it
10/25/2013 1:40:35 PM • Samsung Galaxy... • Answered on Oct 25, 2013
Open mx46533v manual pdf download
ThinkFree document viewer/editor is pre installed. Just download the pdf and open it.I think it may work for u.
10/20/2013 8:38:20 AM • Samsung Galaxy... • Answered on Oct 20, 2013
0answers
3answers
Where is My Profile found on my Samsung Galaxy S5
Samsung Galaxy S5: My Profile on Phone: Hello. I'm not quite sure what you mean by your profile. I will assume you mean you want more information about your phone on your device.. like Firmware version, phone number, IMEI#, Phone Serial#, etc.. Go to: Settings>General>(Scroll Down) Select About Device or Settings>General>Accounts>(select account you want to look at)
1/2/2023 6:21:51 PM • Samsung Galaxy... • Answered on Jan 02, 2023
2answers
Samsung Galaxy Rugby LTE SGH-i547C. Unlock code sgh-1547c 35400******5890 imei code
Question edited for clarity full make and model. Question moved to category. All about PUK Codes and how to get them. https://www.fixya.com/support/r26056685-phone_asking_puk_code and more https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way ..
9/5/2022 9:05:06 PM • Samsung Galaxy... • Answered on Sep 05, 2022
Samsung Galaxy J3V. How do I bypass the FRP without a PC or Wi-Fi?
Question edited for clarity, maker name. Question moved from L.A. Galaxy Soccer to correct category. You can't. You need one or the other. Go to MacDonald's and use their wifi. https://www.google.com/search?q=Galaxy+J3+V+bypass+the+FRP+without+a+PC+or+Wi-Fi ..
7/6/2022 3:12:08 PM • Samsung Galaxy... • Answered on Jul 06, 2022
How do I reset a 2017 series Galaxy J3 Luna Pro with FRP lock?
After the reset, confirm your Google Account and Password. https://www.google.com/search?q=reset+a+2017+series+Galaxy+j3+Luna+pro //
6/28/2022 7:55:15 PM • Samsung Galaxy... • Answered on Jun 28, 2022
2answers
FRP unlock Samsung Galaxy A13
If you want to learn the easy way how to remove or bypass your Samsung lock feature, check this; Forgot Samsung Password? Unlock it With No Data Loss, you will learn the easy way to solve your problem.
5/30/2022 3:17:31 AM • Samsung Galaxy... • Answered on May 30, 2022
2answers
Samsung account
3/28/2022 8:56:13 AM • Samsung Galaxy... • Answered on Mar 28, 2022
3answers
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV.. There are 3 ways to do this.. 1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work. You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV. Note: the MHL adapter may overheat your device if you have it on and working for long periods of time. Youtube example of MHL to TV: How to Mirror or connect Samsung Galaxy s3 to TV 2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps. 3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link Youtube video: How To Use Samsung Link previously AllShare Play
6/8/2021 6:26:32 AM • Samsung Galaxy... • Answered on Jun 08, 2021
2answers
How to unlock samsung galaxy young (GTs5360)too many pattern attempts
If you kust Google this option there are a few options. I have provided the 1st two here. How To Unlock Samsung Galaxy Young and Samsung Galaxy Young DUOS http://sim-unlock.net/simlock/Samsung/Galaxy_Y_S5360/
4/13/2021 4:22:27 AM • Samsung Galaxy... • Answered on Apr 13, 2021
8answers
I lost pictures that had not been saved to the sd card, can they be retrieved?
You can try GT Recovery to restore deleted pictures! Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones. It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks. Key features of Data Recovery - GT Recovery for Android: Preview & selectively retrieve photos and video lost due to any problem Support all Android phones/tablets, like Samsung, HTC, LG, Motorola... Only read and recover the data, no personal info leaking, 100% safe Facebook: www.facebook.com/GT-Recovery-16556868313­68830/ Twitter:https://twitter.com/GtRecoveryapp
3/30/2021 5:44:18 AM • Samsung Galaxy... • Answered on Mar 30, 2021
10answers
Recover deleted messages
no root ! Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now! Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone. Some common situations that lost text messages you can recover from: 1. accidentally deleted texts on your android phone 2. lost text messages after Android 5.0 updated or other Android upgrade. 3. save text messages from water damaged, crashed, broken or smashed Android phone 4. Android deleted text messages randomly by itself 5. Factory restore Android phone. And more..
3/13/2021 4:54:08 AM • Samsung Galaxy... • Answered on Mar 13, 2021
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
1/19/2021 2:36:39 AM • Samsung Galaxy... • Answered on Jan 19, 2021
Samsung Galaxy Gio GT-S5660 Unlocked Quad-Band GSM Android Smartphone Logo
Popular Tags
14 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
unluck manuy patern attempts
  • Cell Phones
