20 Most Recent Fujitsu Siemens LifeBook N6410 Notebook Questions & Answers
My fujitsu N6410 was over heating and now the
If your laptop was overheating, you need to resolve the cause...it may be that the Processor fan is clogged with dust/dirt. Or is has stop working and needs to be replaced. The Beep codes indicates that the video circuit is not working.. If that is the case, you need to R/R the system board. 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2/5/2012 8:18:04 PM • Fujitsu Siemens... • Answered on Feb 05, 2012
I try to boot up my Fujitsu 6410, N series but it
Reboot your computer.. hit f8 a few times at the logo and your menu will come up with an option to restore computer to an earlier time. Select this option and hit enter. If all goes well, you should be able to restore your computer back to before this started happening, pick a date in the list that you know your computer was working fine. It will reboot and you should be able to use your computer like nothing was wrong. This won't delete any of your programs or settings.
10/7/2010 10:05:31 PM • Fujitsu Siemens... • Answered on Oct 07, 2010
I need to change the fan on my fujitsu n6410 and I
Thanks for giving Fixya the pleasure to solve your problem.
Follow these steps to change the fan:-
  • Turn off your Fujitsu and remove the main battery from the bottom of the device. Remove the screws on the underside of the laptop with your Phillips screwdriver.
  • Remove the compartment cover marked "Hard Drive" on the bottom of the laptop and unplug the thick cable connecting the computer to the hard drive. Gently pull the hard drive from its housing.
  • Turn your laptop right-side up and remove the screws on the backs of the two hinges that support the LCD monitor. Now open your laptop so the screen is facing you.
  • Insert the tip of your screwdriver under the edge of the thin plastic plate just above the keyboard. Gently pry it up and remove it from the computer. Lift the keyboard up from the top edge and disconnect the data ribbon connecting it to the motherboard. Remove the keyboard and set it aside.
  • Disconnect the two LCD ribbons that connect the screen to the computer and then unplug the touchpad ribbon connecting the touchpad to the computer.
  • Remove the screws on the sides of the frame underneath where the keyboard used to sit and remove the frame, exposing the internal components of the laptop.
  • Locate the square fan in the left corner of the computer and disconnect the single cable that runs from its side to the motherboard.
  • Remove the screws securing the fan to the computer and replace with the new fan (available from your Fujitsu retailer or online) and reassemble the laptop in the reverse order you took it apart.
6/16/2010 8:36:10 PM • Fujitsu Siemens... • Answered on Jun 16, 2010
Install memory
Turn the PC over with no battery installed or not plugged in, remove cover for the memory slot, replace memory with new, reinstal cover, battery, ac adapter, then power on.
3/6/2010 6:51:11 AM • Fujitsu Siemens... • Answered on Mar 06, 2010
I need a user manual for my n6410 life book.
User manual (pdf) for the N6410 can be downloaded from here.
Good Luck!
2/8/2010 7:45:13 PM • Fujitsu Siemens... • Answered on Feb 08, 2010
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps. in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
11/30/2017 10:28:49 PM • Fujitsu Siemens... • Answered on Nov 30, 2017
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment. Regards, joecoolvette
11/22/2015 5:27:54 PM • Fujitsu Siemens... • Answered on Nov 22, 2015
How do I get into bios
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC. Thanks, Roger
7/22/2015 2:41:52 AM • Fujitsu Siemens... • Answered on Jul 22, 2015
Problem with Fujitsu Siemens PC Laptops 8110
tell about the problems
3/24/2015 10:39:51 AM • Fujitsu Siemens... • Answered on Mar 24, 2015
How to download recovery disc
Recovery disc comes from the manufacturer and looks for the serial number of your computer. You would have to buy a recovery disc from the said manufacturer or just go buy a new operating system CD
7/5/2014 4:35:41 AM • Fujitsu Siemens... • Answered on Jul 05, 2014
0answers
Atheros ar5007eg wpa2 Windows XP
UP DATE DRIVER IF IT S ISN T WORKIN REINSTAL THE DRIWER IF ISNT WORKING FOUND A NEW ONE
12/23/2013 4:44:28 PM • Fujitsu Siemens... • Answered on Dec 23, 2013
My music is distorted and its killing me
GO TO THE VOLUME CONTROL THEN MIXER THEN SPEAKERS THEN ADVASED CONTROL THEN RESTORE DEFAULTS THEN SEE WHAT HAPP
12/23/2013 4:42:22 PM • Fujitsu Siemens... • Answered on Dec 23, 2013
Fujitsu Siemens LifeBook N6410 Notebook Logo
12 questions posted
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu Siemens
  • LifeBook Fujitsu Siemens
Most Popular Question
fujitsu n6410 will not start in safe
  • Computers & Internet
