20 Most Recent
Apple Iphone A1387 Questions & Answers
Attery not charging
Check the charging port and clean with an old toothbrush if found to be dirty.
Reset pass code
There is no reset code .You can connect to itunes and restore from DFU mode (search on youtube for DFU iPHONE )
Remove password fram screen
If would like to remove a pass code from an apple device, you would login and head over to settings. Next click on general > pass code or pass code lock I can't remember which one > now click disable pass code or remove pass code and you will be proceeded to put in your pass code. Now if you've done correctly try to lock and unlock your phone. I hope this helps;)
Apple Iphone A1387
The best was to get past a locked iphone is a complete reset, or a restore from backup.
turn the phone off, hold down the home button, and plug it into the computer and it will restore from the backup
Will not turn off
There may be a problem with your power button. See a technician to look at it and replace if neccessary.
I need to reset and unlock simcard.
To reset the iPhone follow the steps below;
- Begin by holding the sleep/wake button at the top right of the device and the Home button at the bottom center of the face at the same time.
- Hold them both until you see the screen go black. In some cases, you may need to keep holding them even after the red power-off slider appears. If it appears, just keep holding it.
- Wait until the silver Apple logo appears.
- When this happens, you can let go - the iPhone is rebooting.
An iPhone reset should not normally remove or delete any data or settings.(site:http://ipod.about.com/od/iphonetroubleshooting/qt/reset_iphone.htm)
Is your phone locked with any particular network?To unlock an iPhone the remote unlock service would be a better option because, you need not give your mobile to someone else nor do you have any chance to enter the wrong unlock codes. To get such an unlocking service for your iPhone approach
Prounlocking.com and by submitting the country and network to which the mobile is locked to you will be able to remove the restriction from the respective network. This will be a permanent unlocking solution.
Sim insert set is heating
Can you offer any other information? Other then a title about this issue? Unfortunately I can only assume that your SIM port is heating up, if that is what is happening you likely have a faulty SIM card or Phone and one or the other would need to be replaced.
