20 Most Recent
Research In Motion Blackberry Curve 9360 Black Wifi Gsm Quadband 3g At&t Bar Cell Phone Questions & Answers
HOW DO I RESET MY PASSWORD ON FACEBOOK?
go to the login page here:,
Facebook
just under where you input your password you can click on "forgotten password". This takes you to a page where it says "find my account" where you can enter "Email, Phone, Username or Full Name". Try entering one of these (My email gave the best result for me) and follow through the instructions to reset your password so that you can access your account.
I would suggest that you do this fairly quickly since your Faceook has been hacked by someone else for these details you mention to have been changed. Make sure your password is a strong one combining upper & lower case letters and numerals, in this way you will e in less danger of having your Facebook account hacked in the future.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Need to reset my blackberry id and password
Not too much you can do except reset the device to factory defaults and reset up your email, contacts, etc. You should be able to continue to enter in passwords until a point that it will "wipe" device. From there, you can reconfigure your device.
I have forgotten my answer to blackberry recovery
1: Have the user install Desktop Manager 4.7 2: Have the user open a command prompt and type the following and hit Enter: CD X:\Program Files\Common Files\Research In Motion\AppLoader (Where X is the letter assigned to the root drive. 99% of the time it will be C:\ but it can be verified by double-clicking on My Computer.) 3: Once you are at the above path, connect the device and type the following in the command prompt and hit Enter : loader.exe /resettofactory 4: ***Note: If the Application Loader wizard appears, the switch was not typed correctly, cancel it and retry the command ensuring it's typed correctly*** 5: ***Note: If the device has a password, another command prompt window will open requesting the password. Exhausting the number of Password Attempts will trigger a Wipe but it will not remove the IT Policy. *** 6: After entering the correct password and hitting Enter, Application Loader will proceed to wipe the device, including the IT Policy. All data will be erased! Good Luck!
I NEED A PUK CODE
Actually can i correct you.a PUK code is when you have used personal passwords incorerctly and you need access to your phone/sim.To use your phone with another network you need a unlocking code.we make those codes (which are unique to you) using the imei number and prd code, which can be found under the battery on the phone looks like prd-xxxxx-*** , we deliver our unlock codes by email in about 2 minutes with instructions. at http://blackberryunlocking.biz/ and you can also watch our video showing the instructions in action http://www.youtube.com/watch?v=I2cPTIVV6GY
