20 Most Recent Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive Questions & Answers
Hello there Alex is on your service tonight :)
Well, this is common laser faliure, after working for several years they just go mailfunctioning and you can't fix them. I highly advice you to keep that one for reading what it can read now, and to buy new device since they are really cheap nowdays, you can get them from ebay or amazon.com under 25 bucks.
Thats the situation, I wish you best of luck snake :)
Please rate my solution if you can that would be nice :)
And enjoy your remaining hours of this day :) Alex
Sony... | Answered on May 05, 2011
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sony... | Answered on Apr 04, 2011
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Sony... | Answered on Apr 24, 2010
Check device manager in control panel under hardware to see if you have a problem with anything (a big yellow check). The most likely casue is that your DVD burning software (not the microsoft programs) did not install properly. Find out the exact info about yours by downloading a freeware program called Belarc Advisor (Googe it), Oddly enough, you don't need drivers for the CD/DVD drives. They aren't even recognized unless you have a non-microsoft burning program. After you find out what burning software you have-- you have to seek a download at the computer manufacturer's website, if it came with the computer, as it may be a special program not related to the burning software if you purchased from the software manufacturer---go to their website for downloads or upgrades,and that should get you going.
Sony... | Answered on May 12, 2009
Heres Your Answer:- Supported DVD Formats DVD-ROM • DVD-Video.
Mike @ compurepair.
Your Drive Does not support DVD+R Only -R.
View Here:- http://www.aprmedia.com/product.php?pid=3974
Sony... | Answered on Jan 22, 2009
Try playing with VLC Player . It works great
Sony... | Answered on Sep 15, 2008
Reinstall nero and search google for removing nero scout
Robert
please rate the solution.
Sony... | Answered on Sep 13, 2008
just wondered if you got it from office depot?
also does this thread help you?
http://club.cdfreaks.com/f44/ativa-18x-internal-lh-1h18a-217118/
Sony... | Answered on Apr 09, 2008
get the filtercheck 4.6 and remove all filters .. restart.. done
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Sony... | Answered on Mar 23, 2008
This is because the model you mentioned is just a combo drive. It is not a dvd burner. You can watch dvd's with it but not burn them. The way manufacturers word the advertising leads some people to believe that they have a dvd and cd burner. All you have is a cd burner / dvd player. What you want is a dvd-rw / cd-rw drive. Sorry! I hope this helps.
Sony... | Answered on Dec 05, 2007
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
Sony CRX... | Answered on Oct 20, 2013
1K0-TN1K-TPQK-CRWD
1K0-EH6K-4WL7-HGKT
934B0MRRG-32KX1L12L
LNWX2L5Y4-F93KBX7CX
NY42SX8G5-FDPM35195
I hope these will work and help you ! :)
Sony Computers &... | Answered 3 days ago
You probably need more ram memory. Also try playing a video in your dvd player. If it plays slow and choppy you definitely need more ram memory.
If you are trying to play a video from a website (streaming) then three things can affect how smooth it plays.
1) Memory - your ram memory might be low
2) The website might be experience heavy traffic from many users.
3) The Line Speed of your internet connection from your service provider might be slow. For example: AT&T sells about 3 or 4 different packages and each one increases the line speed for uploading or downloading. If you buy the low end package the line speed is very slow on uploading and downloading or streaming. It's ok for just surfing, but nothing else.
Sony Computers &... | Answered on Nov 08, 2019
1st leave the battery out,
then power only with AC power pack
push power for 10seconds and releases.
the batteries are bad, as more are, in the wild. most.
Sony Computers &... | Answered on Sep 12, 2019
Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive Logo
12 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
cannot ply dvd but
  • Computers & Internet
