20 Most Recent Whirlpool LGR8648L Gas Dryer Questions & Answers
2answers
Whirlpool gas dryer turns on drum spins exhaust is
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
7/28/2012 11:08:57 PM • Whirlpool... • Answered on Jul 28, 2012
Lent and dryer debris building
Yes the baffles could be removed to clean them by removing the lint filter,in the top where the filter goes are 2 phillips head screws,remove them,use medium sized straight blade screwdriver and place it in the seam between the top in and front panel and pop up the top,them pivot back against the wall(dont worry it is hinged in the rear and wont fall off). You will see the drum and can remove the screws that screws that hold the baffles in place,to rotate the drum to get to each baffle rotate it by hand in a counterclockwise direction.
Gene
8/7/2011 1:02:01 AM • Whirlpool... • Answered on Aug 07, 2011
Dryer does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
6/19/2011 8:01:10 PM • Whirlpool... • Answered on Jun 19, 2011
Where is the regulator?
The regulator is built into the top of the gas valve. The picture above
shows what must be done to convert the valve to LP gas usage. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/9/2011 6:39:20 PM • Whirlpool... • Answered on May 09, 2011
HI my whirlpool gas dryer
The gas coils are weak and will need to be replaced.
Kelly
3/24/2011 10:17:02 PM • Whirlpool... • Answered on Mar 24, 2011
The dryer is not heating up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
11/15/2010 3:03:34 PM • Whirlpool... • Answered on Nov 15, 2010
Hi Fixya: My son ran a load of his clothes in our
soak white towels in bleach,wring them out, and run the dryer
10/24/2010 3:17:10 PM • Whirlpool... • Answered on Oct 24, 2010
Whirlpool gas dryer we have the ignitor comes on,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
9/12/2010 10:01:13 PM • Whirlpool... • Answered on Sep 12, 2010
How to change a broken belt on gas dryer
Hi
Thanks for using FixYa. Please check this video on how to replace the belt in dryer. Also check the tensioner pulley and replace it if its bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
7/31/2010 10:51:02 PM • Whirlpool... • Answered on Jul 31, 2010
We are in a new house and trying to figure out how
As short as possible with no turns if possible. Ideally it would be short and stright, If possible have someone small that can climb over machine after tighting the clamps. Use a aluminum hose and snips or dikes to cut. Do not use the plastic ones they are a fire hazard and a code violation in many states.
7/11/2010 11:27:03 PM • Whirlpool... • Answered on Jul 11, 2010
The gas heat stopped today
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
7/11/2010 9:08:48 PM • Whirlpool... • Answered on Jul 11, 2010
I have a dryer that runs but no heat. I removed
the fuses are usually found at an appliance parts store. You can google "whirlpool dryer parts" and find a parts store near you or one you can order from over the internet. I have replaced many of those, and they cost between 20.00 and 30.00 dollars.
6/18/2010 8:37:13 PM • Whirlpool... • Answered on Jun 18, 2010
Not heating
If it has been moved recently or just jostled around the small heater element that prompts the gas valve to open up may have broken, open the front cover and check out the element, it should make a complete circuit from and back to the wire connector. I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
6/14/2010 3:10:58 PM • Whirlpool... • Answered on Jun 14, 2010
Heating fuse
There is a thermal fuse and a thermal cut off that can stop the heat entirely.
If you have some heat but not enough these are not the issue, let me know and I can go deeper if needed.
The thermal fuse is located behind the back panel just to the left of the exhaust outlet. It is white with 2 blue wires going to it.
The thermal cut off is behind the back panel on the right side about 1/2 way up the metal box. It also has 2 wires going to it (usually red).
4/24/2010 2:49:28 PM • Whirlpool... • Answered on Apr 24, 2010
CANT FIND THERMASTAT
its behind rear panel on the blower housing
4/16/2010 5:57:29 AM • Whirlpool... • Answered on Apr 16, 2010
GAS DRYER MODEL LGR8648LW DRUM SPINS BUT NO HEAT.
If you have a gas dryer...
If your dryer is electric..
heatman101
4/15/2010 1:40:38 AM • Whirlpool... • Answered on Apr 15, 2010
2answers
NOT ENOUGH HEAT TAKES 3 TIMES THROOUGH TO DRY
i would check the thermostat first then change the igniter
4/13/2010 11:25:10 PM • Whirlpool... • Answered on Apr 13, 2010
Whirlpool LGR8648L Gas Dryer Logo
35 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
not enough heat takes 3 times throough
  • Dryers
