20 Most Recent
Whirlpool LER2614JQ Electric Dryer Questions & Answers
My Dryer won't heat up
You will need an ohmmeter to check the element and the hi limit thermostat and the non resetable thermal fuse. These are all axcessed through the rear panel if the dryer.
3/27/2009 3:07:46 AM •
Whirlpool...
Answered
on Mar 27, 2009
Fuse
This electric dryer has a thermal fuse. If blown, the drum will not turn. On a gas dryer the drum will still turn but no heat. The thermal fuse is located on the blower housing. You have to remove the back panel to get at it. It will be the white fuse located right above the fixed thermostat. Two wires going to it. Catriver.
4/26/2008 10:37:58 PM •
Whirlpool...
Answered
on Apr 26, 2008
Dryet
Shelly on some of the older models they used a inline resistor on the dryers timer. It looks like a inline fuse comming off the timer. If it goes bad the timer will not stop. Check the attachment. Cost around 17.00, Catriver, post back. Part number 3401076
4/2/2008 3:14:06 PM •
Whirlpool...
Answered
on Apr 02, 2008
Whirlpool LER2614 repair
The problem was that the dryer did not work when the start button was pushed.
The cause was the paddle that controls the door switch. I fixed it but thanks to those who gave suggestions.
3/31/2008 8:55:53 PM •
Whirlpool...
Answered
on Mar 31, 2008
Drum won't turn
if your lint screen is on top of dryer pull it out and remove the 2 screws under it. then there are 2 clips under the front edge of the top. with a putty knife you can press the clips to raise the top. after top is up look inside on the right and left top part of the front of the dryer there is a screw on each side should 1/4" or 5/16" head. remove thoughs screws and front folds forward and lifts up to be removed.
11/25/2007 6:42:18 PM •
Whirlpool...
Answered
on Nov 25, 2007
Problem with my dryer
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
10/7/2007 4:34:49 PM •
Whirlpool...
Answered
on Oct 07, 2007
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works.
Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary.
Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat.
Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction.
Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly.
Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition.
Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly.
Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues.
Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
Whirlpool duet model YWED9300VU0
Try kit 4392067. It's the 4 roller wheel kit with belt and pulley. I use them all the time on that model, but without the Y in the beginning. Not sure what the variation is there.
