20 Most Recent GE CustomStyle PSC23NSTSS Stainless Steel Side by Side Refrigerator Questions & Answers
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
GE CustomStyle... | Answered on Dec 01, 2013
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
GE CustomStyle... | Answered on Nov 02, 2012
Most times this is a defective fresh food section door light switch located in this photo as location number 609. Click Here=> PSC23NSTESS Fresh Food Section I am going to send you the service manual for your model and the information that explains how to change the switch is on page 19. If you do not already have the new free Adoobe Reader installed on your computer click here=> Adobe Reader X (10.1) Just make sure to uncheck the items not needed during the download. There also could be another problem related to the mother board that can also keep the light on while door is close but not likely. The part number for the light swirch is=> WR23X10175 Light Switch Information on how to test the switch is also on that page. Until we have repaired the problem please unplug and remove the lights because this heat will keep the refrigerator running and possibly melt the plastic housing holding the bulbs. Click here for the=> GE Artica/Profile Service Manual
Here is another page with information and wiring diagrams=> GE Artica/Profile Technical Information
I will be here to assist you if you have any questions so feel free to let me know, Thanks Sea Breeze
Please rate this solution and as always Thank You for using Fixya!
GE CustomStyle... | Answered on Jun 21, 2011
need more info on unit .how old ? and model would be helpful
GE Refrigerators | Answered Yesterday
sounds like the cutting grid is broken .look at grid and see wire broke .if it is you will need a new cutting grid.
there is a connection bottom of freezer door ,behind kick plate .remove kick plate look at connection see if its has corroded . that is where the problem is.
GE CustomStyle PSC23NSTSS Stainless Steel Side by Side Refrigerator Logo
22 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
vince
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
light wont shut off heats
  • Refrigerators
