20 Most Recent
GE GTS22WCP Top Freezer Refrigerator Questions & Answers
My 9-year-old refrig (GE GTS22WC)
Ok this is more than likey cold control problem. I look up on sears found the part number. It is WR09X10104 and it is only 30 dollars. I would give a try. The part is located in that long piece in the center. Unplug the box. Remove the four 1/4 screws. Pull down center piece. It will have a gang plug. Unplug it so you can change the cold control. Reverse the order This will solve your problem.
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Circuit board
Whats the fridge doing? please be specific. is the fan running in the freezer? is the freezer working? when did it happen? how long ago? all of a sudden? the more details the better
