Since it worked OK before you moved it, I might suggest that it may be leveled too low in the front, thusly not allowing the defrost water to drain into the defrost pan.
Ascertain that the unit is leveled a 1/4 bubble high in the front...if you have access to a good level.
Or you can elevate the front with the doors open 90 degress, and with a very slight nudge, the doors should swing closed by themselves.
Installation tip: Proper installation of a refrigerator is both easy and important. The primary concerns are that the unit has sufficient clearance from the walls for proper ventilation, that it is not pinching any electrical cords or water lines, and that it is level. Many refrigerators must be tilted back slightly so that the doors self-close. Consult your owner's manual for further installation instructions
Need a users manual? Get one here at:
www.managemyhome.com
For home management information, go here:
www.homemanagement.services.officelive.com
If this does not help, try this link for some good tips. Courtesy of
www.repairclinic.com
http://www.repairclinic.com/0088_4_3.asp
