20 Most Recent KitchenAid KSRT25CRSS Stainless Steel Side by Side Refrigerator Questions & Answers
KSRT25C display doesn't work after power outage
No sorry there is no reset button. If this happened during an outage there is a possibility that there was also a surge. Electronic control boards are sensitive to sudden changes that may have swelled the tops of the capacitors on the control board. HERE=> 2303843 Dispenser Control Board bd6d9f22-038b-4d01-bbd3-c974828eaedd.jpg Have someone unplug the power and look over the 2303843 Dispenser Control Board Sometimes you can see damage but most times you will not see a problem with the board. . I am here should you need me, Thanks John Tripp Appliance 911
4/13/2014 12:45:34 AM • KitchenAid... • Answered on Apr 13, 2014
How do i defrost manually
Pull the plug and use a heat gun or a hair dryer..
heatman101
5/11/2011 12:43:29 AM • KitchenAid... • Answered on May 11, 2011
I would like to defrost it manually
This is intended as a guide to defrosting a refrigerator that has the freezer on the top. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Hope this help in solving the problem.....
5/10/2011 4:48:42 PM • KitchenAid... • Answered on May 10, 2011
2answers
KitchenAid French door refrigerator. How do I repair a non-working water Dispenser on it please?
Troubleshoot step by step and if that fails, resort to a professional: Check the Basics: Make sure the refrigerator is plugged in and receiving power. Verify that the water supply to the refrigerator is turned on. Inspect the Dispenser Actuator: The dispenser actuator is the component that activates the switch to send voltage to the dispenser. Check if the dispenser actuator is damaged. If so, replace it with a new one. I list a procedure for testing this actuator at the end of these basic steps. Frozen Water Tube: Disconnect the water supply tube at the bottom of the door. Blow air through it. If air doesn't pass through, the water supply tube may be frozen. Thaw it out and ensure the freezer is set to the proper temperature (0-10°F) to prevent future freezing. Water Inlet Valve: The water inlet valve opens to supply water to the dispenser. Ensure the water pressure to the valve is at least 20 psi. Use a multimeter to test the water inlet valve for continuity. If it lacks continuity, replace it. Check Water Filter: Remove the water filter and dispense water. If flow increases, the filter may be clogged or incorrectly installed. Replace the water filter if needed. Verify Water Supply Valve: Ensure the water supply valve (connected to the refrigerator) is fully open. If disconnected during service, it might not have been turned back on fully. And now, the testing of the actuator. To determine whether the dispenser actuator in your KitchenAid refrigerator is damaged, follow these steps: Visual Inspection: Look closely at the dispenser actuator. Check for any visible signs of damage, such as cracks, chips, or breakage. If you notice any physical damage, it's likely that the actuator needs replacement. Functional Test: Press the dispenser lever or button as you normally would to dispense water. Observe the response: Does the actuator move smoothly and engage the switch behind it? If the actuator feels stiff, loose, or doesn't move at all, it may be damaged. Listen for Clicking: When you press the dispenser lever, listen for a clicking sound. The actuator should make a distinct click as it activates the switch. If there's no click or an unusual noise, it could indicate a damaged actuator. Multimeter Test (Advanced): If you have a multimeter, you can perform a continuity test on the actuator. Disconnect the refrigerator from power. Remove the actuator cover (if applicable) to access the actuator. Set the multimeter to the continuity (ohms) setting. Touch the multimeter probes to the actuator terminals. If there's no continuity (infinite resistance), the actuator is likely faulty. Remember to exercise caution when working with electrical components. If you're unsure or uncomfortable performing these checks, consider seeking professional repair assistance. Remember to consult your Owner's Manual for specific instructions related to your model. Much of this information comes from the RepairClinic site.
3/17/2024 4:42:35 AM • KitchenAid... • Answered on Mar 17, 2024
KitchenAid Refrigerator Model KSRS25Q. Are Replacement door seals available?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved for correct category. Yes they are, direct or from Parts Suppliers. https://www.google.com/search?q=KSRS25Q+WH11+door+gasket ..
1/4/2024 10:29:11 PM • KitchenAid... • Answered on Jan 04, 2024
KitchenAid refrigerator superba is not cooling. Frizzer is fine
Possibly you r hhermostat in Fridge section gone bad. (if freezer working then most likely (if freezer at top & fridge has Iced up or food in the freezer or fridge Is Blocking the Air vents inside that circulates the cool air flow to Bottom or top, check & listen to see if Fan is working inside freezer /fridge worst case scenario is (if you have a p.c board on top , that could b a Fault there also (then you need a Tech, ).
10/26/2023 4:15:12 AM • KitchenAid... • Answered on Oct 26, 2023
KitchenAid KBFC42fts - light turns on but control panel won't work. I have turned off and back on via the circuit breaker. Is there a reset trick on the control panel?
You didn't say but you need to turn the breaker off for 10 minutes. Best to you.
6/22/2023 1:51:56 PM • KitchenAid... • Answered on Jun 22, 2023
My KitchenAid KFCS22EVMS french door refrigerator is leaking water from the bottom.
I would check the door seals as if not sealing damp air will enter and condense, causing water everywhere.
5/20/2023 7:28:10 AM • KitchenAid... • Answered on May 20, 2023
Hi, Kitchenaid kbfc42fts interior controls and lights blinking no alarms
If the interior controls and lights in your KitchenAid KBFC42FTS refrigerator are blinking but there are no alarms or error codes displayed, it may indicate a problem with the refrigerator's control board or power supply. Here are some steps you can take to troubleshoot the issue:
  1. Power cycle the refrigerator by unplugging it from the electrical outlet or turning off the circuit breaker that supplies power to it. Wait for a few minutes and then plug it back in or turn on the circuit breaker.
  2. Check the refrigerator's power supply by ensuring that the electrical outlet is working properly and that the power cord is securely plugged in.
  3. Check the control board for any signs of damage or corrosion. The control board is usually located on the back of the refrigerator, behind a panel. If you see any damage or corrosion, you may need to replace the control board.
  4. Check the wiring connections between the control board and other components such as the lights, fans, and sensors. Loose or damaged wiring can cause communication issues and blinking lights.
If none of these steps resolves the issue, it is recommended that you contact a professional appliance repair service for further assistance. They will have the necessary tools and expertise to diagnose and repair the problem.
4/12/2023 3:18:20 PM • KitchenAid... • Answered on Apr 12, 2023
No cooling and high pitched noise from KitchenAid fridge
  1. Check if the fridge is level. If not, adjust the leveling legs.
  2. Verify that the condenser coils are clean and free of obstructions.
  3. Check the temperature settings and adjust if needed.
  4. Ensure that the evaporator fan is working properly and not obstructed.
  5. Check the condenser fan for proper operation.
  6. If the high-pitched noise persists, it could be a sign of a failed fan motor or other mechanical issue, and a professional repair may be necessary.
1/29/2023 7:15:09 PM • KitchenAid... • Answered on Jan 29, 2023
Kitchenaid kmhs120ess-10: The bottom handle bracket is loose. How can I disassemble the door to tighten the bracket screw?
Hi, Please remove any facades on the microwave first. This should expose the screws the keep the door on the microwave. Once you remove the door then you can achieve your goal. You might also call kitchenaid to get schematics for the microwave to help you when removing the facades. Thank you.
10/31/2022 10:46:58 PM • KitchenAid... • Answered on Oct 31, 2022
Lights out in kitchenaid frige after power outage
Not knowing all the details I am just guessing here I have seen this happen more then once, when power goes off and comes back on sometimes there is a power search causing too much electric in one spot and burning out the component such as a light bulb but that is a easy fix, you can buy an appliance 40 watt bulb just about anywhere and replace it
8/12/2022 6:19:13 AM • KitchenAid... • Answered on Aug 12, 2022
2answers
KSRP22FSBL01 not making ice
I would say more than likely the small tube carrying water to the ice maker probably needs to be blown out small air blower or through or through same tube by mouth
4/8/2022 10:12:24 PM • KitchenAid... • Answered on Apr 08, 2022
Model KRFC300ESS. How can I get french door hinge to close?
hinge damaged /bent or worn and the hinge has adjustments on it --if low make a bushing from plastic-washers not cardboard
4/5/2022 10:50:34 PM • KitchenAid... • Answered on Apr 05, 2022
KitchenAid dutch door water dispenser on outside, intermittently working
Sounds something is loose in the filter, have you tried a replacement .
3/12/2022 4:57:12 PM • KitchenAid... • Answered on Mar 12, 2022
I need the KitchenAid KSRG25FKSS05 wiring diagram. Please help.
This is going to be the best you get.... https://www.partselect.com/Models/KSRG25FKSS05/
1/16/2022 5:43:13 PM • KitchenAid... • Answered on Jan 16, 2022
KitchenAid KSRT25CRSS Stainless Steel Side by Side Refrigerator Logo
4 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
ksrt25c display doesnt work after power
  • Refrigerators
