20 Most Recent
Blu D510 Studio 5.3 Unlocked Phone with Dual SIM Card Support - US Questions & Answers
Help
You should have a menu option which will have a language option - select english...
Too many pattern attempts& invalid username and password on blu studio phone 5.5
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
- Volume Up + Home + Power
- Volume Down + Power
- Home + Power
- If none of the above work, do a web search for your phone's model plus "recovery mode".
- 3-
- Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
- You will be asked to confirm the factory reset.
- 4--
Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
Have Blu View 3 that can't make or receive calls, can you please help me?
I remember reading somewhere about an issue with so called off brand phones(Non-Flagship)... as im in the same boat(Using Cubot Brand) and talking with my service provider today. they stated my phone isnt on the list or compatable with the at&t network anymore(atleast the calling part of it) you should still be able to use data & text. Lucky i already have a third party app for a 2nd phone and also use google voice, both of which let me make calls using my data. and if i need to contact someone i can either send a voice/text message as normal.I have read somewhere that i believe blu is trying to get onto the att network. So hopefully they do because ill just switch back sense they are a good phone company. Hope this info helps.:Edit: Even if it is 4g LTE, also spoke with a friend who has a 5g non-flagship whos carrier uses att and she isnt able to make calls from the phone but the speeds are still there. So hopefully something gets fixed because I believe this is some B.S. to lock us out because we dont want to pay for a iphone or samsung
How do i block a number? BLU advance 5.0
1. Touch the icon that says "Phone" on your main screen.
2. Click on the entry for the number you want to block under "logs."
3. Press the menu button on your BLU advance 5.0.
4. Select add to "reject list."
How can I retrieve deleted text messages
heHello,
Two ways you can get back yourdeleted messages from the phone.
1)From the service provider.
WHAT YOU NEDD TO DO TO GET BACK THE MESSAGE FROM THEM IS TO CALL ON THEM
FROM THE CUSMER CARE CENTER.
2)From the other side that the message was send from. Thanks.
