20 Most Recent
Whirlpool AD25BBR 25 Pint Per Day Dehumidifier w/ AccuDry Sensing System & EZ-Empty Bucket Humidifier Questions & Answers
The unit is leaking water,
More
than likely, the drain tube or hole that delivers the water into the
collection bucket is clogged. To clear the clog: First turn the unit OFF and unplug it from the wall outlet. Use an 18 -20" long
plastic Zip Tie, that will fit into the drain tube or hole. DO NOT use a wire coat hanger for this.
Carefully insert the Zip Tie into the hole or tube and gingerly work
it in until you reach the bend of the tube. This is where it gets a
little tricky, because you must get past that bend, to be effective.
Once the Zip Tie has reached it's limited reach or it has bottomed out.
Slowly pull it back out, while rotating it. This will remove any clogs,
so be prepared for water to follow.
Hope this helps you solve that leaky situation. Please let me know.
1/1/2013 5:02:15 PM •
Whirlpool...
Answered
on Jan 01, 2013
DEHUMIDIFIER IS RUNNING BUT NOT
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
7/28/2011 5:39:09 PM •
Whirlpool...
Answered
on Jul 28, 2011
Dryer not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
3/4/2011 9:59:57 PM •
Whirlpool...
Answered
on Mar 04, 2011
How to use it was left in my new house
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/4/2010 10:05:04 PM •
Whirlpool...
Answered
on Sep 04, 2010
Water in carperting
this might sound stupid but is it pitched so that it drains outside instead of level or in towards the house?
5/18/2010 12:34:08 AM •
Whirlpool...
Answered
on May 18, 2010
I am about to throw
if your dehummidifier dumps water all over the floor, then it, means its overfloating.
If your dehumidifier is overflowing, you can test the overflow prevention switch with a volt-ohm meter.
1) Unplug the dehumidifier and remove the switch.2) Disconnect the leads and clip the leads to the terminals on the switch.
3) Check the pan or reservoir and empty it if necessary, or make sure the drain isn’t clogged.
4) Straighten any kinks or bends in the unit’s hose.5) Set a volt-ohm meter to the RX1 scale (or to K-Ω or Ω resistance on a digital meter) and depress the bar or trip lever on the switch. If the meter’s needle shows no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
You might visit the link below, it might be of help:
http://www.repairclinic.com/Dehumidifier-Troubleshooting
Take care.
5/17/2010 11:05:18 PM •
Whirlpool...
Answered
on May 17, 2010
Compressor doesent run, fan runs
brand new hunter humidifier was working for about a week now there's no water in tank it has all leaked to the floor tank is empty
4/11/2010 2:34:33 PM •
Whirlpool...
Answered
on Apr 11, 2010
Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
4/4/2010 3:13:19 PM •
Whirlpool...
Answered
on Apr 04, 2010
