20 Most Recent
Oster OGB81101 1.1-Cubic Foot Microwave Oven, 1 ea Questions & Answers
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
My Oster microwave only allows me to use it by pressing one button. After the microwave stops, none of the buttons will work on it again until I unplug it and repeat the process.
The issue you are describing with your Oster microwave, where it only allows you to use it by pressing one button and then none of the buttons work again until the microwave is unplugged, could be caused by a few different issues. Here are a few things you can check:
- Check the control panel: Make sure that the control panel is not damaged or malfunctioning.
- Check the circuit board: The control board may be malfunctioning, which can prevent the buttons from working properly.
- Check the door switch: Make sure that the door switch is working properly. If the door switch is not working properly, the microwave may not function properly.
- Check the touchpad: Make sure that the touchpad is not damaged or malfunctioning.
- Check the power supply: Make sure that the power supply is providing the correct voltage and that it is not damaged.
- Check the fuses: Check for any blown fuses, replace them if necessary.
If none of these steps resolve the issue, I would recommend contacting the Oster's customer support for further assistance. They may be able to provide additional troubleshooting steps or may recommend a qualified technician to repair the unit.
