20 Most Recent
Frigidaire AEQ7000EG Affinity Series Electric Dryer Questions & Answers
My dryer is not heating
THE PROBLEM MAY BE OF SEVERAL THINGS
1. ELEMENT BURNT OUT
2. THERE ARE NORMALLY TWO TEMPERATURE STATS
ONE CONTROLS THE TEMPERATURE/ SWITCHES THE HEATER ON AND OFF AND THE OTHER IS A OVER TEMPERATURE STAT, IF THIS TRIP'S IT WILL NEED REPLACING AND ALSO THE WORKING STAT, THAY COME AS A SET.
3. WIRING CONNECTION ON HEATER ELEMENT BURNT OFF
4. PROGRAMMER CONTACT /CABLE PROBLEMS
MAY BE CHEAPER TO BUY A NEW ONE AROUND £200
GOOD LUCK
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
