20 Most Recent Frigidaire Affinity Series FASE7073LA Electric Dryer Questions & Answers
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Frigidaire... | Answered on Aug 13, 2014
The code E68 indicates that a button is stuck. Check the buttons by pressing them one by one to find the stuck button.
Frigidaire... | Answered on May 30, 2019
The E9X codes all point to a faulty control board, as does the fact that the PF code canno tbe cleared. Just make sure none of the buttons are stuck down before you replace it...copied from another forum im in
Frigidaire... | Answered on May 29, 2019
...E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring.
Frigidaire FEQ1442ES Electric Dryer E5b error code - Questions ...
www.fixya.com/search/p439987-frigidaire_feq1442es_electric_dryer/e5b_error_code
Videos
https://www.google.com/search?q=error+code+E5b+on+Frigidaire+affinity+dryer
Frigidaire... | Answered on Mar 21, 2019
If you use fabric softener sheets in your dryer, they eventually will deposit enough residue in your lint trap to close up the mesh. Usually you cannot see the residue, although it is blocking the movement of air through it. My advise would be to remove the lint trap and run it under hot water and clean it well, then try the dryer with the clean lint trap. I hope this works for you and solves your problem.
Frigidaire... | Answered on Jan 02, 2019
Check the owners manual or manufacturers website for error codes. Most likely cause...a bad control board.You tube will most likely have "how to replace" videos for your assistance.
Good luck...
Frigidaire... | Answered on Dec 23, 2018
Typically there is a wiring diagram inside console area or on back of dryer.
Frigidaire... | Answered on Dec 21, 2018
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
Frigidaire... | Answered on Dec 20, 2018
Frigidaire Affinity Series FASE7073LA Electric Dryer Logo
4 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
error e52 frigidaire affinity
  • Dryers
