20 Most Recent Whirlpool DU805DWG Dishwasher Questions & Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Whirlpool... | Answered on Mar 03, 2011
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Whirlpool... | Answered on Feb 27, 2011
i don't know. as it is new, i would call the seller or the manufaturer to see if this a normal condition or if a free service call is necessary.
Whirlpool... | Answered on Oct 26, 2019
If you have verified the lines are not clogged, there is a possibility that the replacement pump is defective.
Whirlpool... | Answered on Sep 26, 2019
Where is it leaking from? It'd it is under the door, check the door gasket for tears.
Whirlpool... | Answered on Sep 15, 2019
cycle timer. Mine wouldn't shut if timer were in the wrong place.
Whirlpool... | Answered on Sep 05, 2019
Actually, the internal control board is suspect.
Whirlpool... | Answered on Aug 13, 2019
Please check your normal water supply it's above 35'c no need to contact any component
Whirlpool... | Answered on Jul 19, 2019
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Whirlpool... | Answered on Jul 17, 2019
I have the solution! Had error 4 and had the repair guy come....he said its caused by too many suds...if you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completly) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone! Easy Peesy. I called whirpool about this, and why they could not tell me how to fix it is beyond me......they told me to press and hold the start button...i dont think even they know how to fix it! So...I got to do this under warranty, now hopefully you get to fix it for free and we all win. Yay!
Whirlpool... | Answered on Jul 11, 2019
Are you sure the cycle is complete?
If it is drying dishes then you will be interrupting the cycle. It is possible to cancel cycle and start over.
Whirlpool... | Answered on Jun 27, 2019
There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. It could be a corrosion problem:
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
Whirlpool... | Answered on Jun 14, 2019
Whirlpool DU805DWG Dishwasher Logo
8 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
white powder residue left
  • Dishwashers
