20 Most Recent
Whirlpool 24 in. DU940QWD Built-in Dishwasher Questions & Answers
We are having a problem
Most of the problem in dishwasher is related to float switch that informs the timer to move to the next cycle. There are two float switches, one for water level and the other one for water empty or drain. These two must move else the cycle will continue for ever.
E1 error but no leaking found .
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
When we turn on the dishwasher it doesn't fill with water
Hi I am vortash it sounds like this is a water level switch ( vacum ) problem it is telling the machine there is water in and the machine carries on and doesn't open the flow valve to put the water in .. as it thinks it is full . or the controller is faulty and need s repalcing .. try replacing the level control first as this would be cheaper than the programer.. Regards Vortash
E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Dishwasher problem
hi make sure the top draw is pushed all the way back s there is a little rubber o ring that the shelf has to push in to
Wonderful Whirlpool Washus Interuptus!
My plan was to see if I could find you a service manual, but strangely, the only reference to that model number is your post here! My guess is the D6 is 'D for Dishwasher' and 'Series 6' or 6 models in that current series.
If the machine has been laid up or little used, check all the connection on the control board. Clean pins and plugs with electrical switch cleaner
https://www.google.com/search?q=DU940QWD6
8/26/2023 5:52:50 PM •
Whirlpool...
Answered
on Aug 26, 2023
