20 Most Recent
Lenovo 3000 N100 0689 Notebook Questions & Answers
Where is 0689 wi fi key
One way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
Need cracked screen replacement. Would like to
I have the same lenovo 3000 N100 with a dead motherboard.I could either sell it to you at the price of a screen or perhaps could buy yours with a broken screen.Please let me know,Alex (botpot @ gmail.com)
Audio not coming after installing
First, make sure you installed the correct driver.
Then go to the control panel and under "sound" check to see if the speakers are muted. Also, check the speaker volume.
Go to the sounds tab and see if, when you click an event that has a sound assigned to it, the little arrow for preview is dark. If it is dark and the volume is up and not muted, you should hear sound. If it is grayed out, you your computer doesn't recognize the sound card or drivers.
I didnt find audio drivers
Try to go to the Lenovo website and there at support type the model of the laptop and download the Lenovo update utility and it will update you're laptop's drivers.
Not coming audio sound
click on start and click on help and support type in the serch bar device manager follow the links and open the page, it will show every item that you pc has scroll down and find sound if theres a ? mark against any double click it and it should serch for the software direct from your computers memory.. try it it worked for me
I have Lenovo 300 N100
The backlights in your monitor are part of the display panel itself and cannot be changed..
You may need to replace the entire display panel.
However, start by having the inverter which runs the display panel backlighting checked as the fault may lay in it rather then in the panel itself.
Now, you must be VERY careful when handling this inverter as it is more then capable of giving you a nasty electric shock.
To be safe, have the panel and the inverter checked by a professional.
NEVER handle an inverter that is connected to a supply rail..
The inverter is usually located inside the monitor housing of the laptop and care must be taken to open up the housing. Most housings are held together with formed plastic clips and you simply prise the fascia off the front very carefully. DO NOT apply any pressure to the display panel during this.
If the inverter is not in the monitor housing, then it will be under the keyboard and in this case, I would advise you take the laptop to a professional as replacing the wrong screw into the wrong hole can cause serious damage to the mainboard and destroy the laptop.
Lenovo 3000 N100 power failure
I troubleshot my problem. and this is what I did.
I "overdischarged" the battery.
I took the battery out of the laptop, wiped it down with a clean DRY cloth, blew on the connectors, to eliminate any dust, etc.
Put battery back into the laptop, plugged in the AC adapter let charge for over an hour.
surprise, !!! it all started working again. ;-)
Not working audio device
Hi. I would suggest that you uninstall the AUDIO driver and install the latest audio driver or High definition audio driver on your machine. You can download the latest drivers for your machine at the Lenovo Driver support website at consumersupport.lenovo.com, just enter the serial no. of your machine and it will give you every software and drivers that you need for your laptop. Hope this helps
