20 Most Recent Samsung DMR78AHS 6 Cycle Stainless Dishwasher, 6-layer insulation reduces sound, triple filtration prevents residue build up, eliminate pre-rinsing Questions & Answers
Why does it stay on 22 minutes for a prolonged time also 2 minutes for an hour
You may have either a bad heating element, or a bad controller. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
3/12/2015 6:07:15 AM • Samsung DMR78AHS... • Answered on Mar 12, 2015
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
2/16/2015 4:21:12 AM • Samsung DMR78AHS... • Answered on Feb 16, 2015
My Samsung vrt washer has hour glass light on and will not run
It is probably in timer mode. Consult your user manual.
3/28/2024 7:46:51 AM • Samsung... • Answered on Mar 28, 2024
How to rest temp controls after a power surge on a samsung rt18m6213ww/aa
First things to try: 1. Unplug the fridge and move it away from the wall. 2. Inspect the power cord for damage. Replace the power cord if it is damaged. 3. Plug the fridge back into the wall outlet. 4. Set the temperature control to the desired level. 5. Push the "Reset" button, located near the temperature control panel, to reset the temp control settings. The Reset button is usually red in color. 6. Move the fridge back to its original position.
10/31/2023 2:00:19 PM • Samsung... • Answered on Oct 31, 2023
Hi my samsung dishwasher gives H4 error code how do i fix the problem?
Incoming water temp or pressure is too high
10/4/2023 9:30:56 PM • Samsung... • Answered on Oct 04, 2023
Samsung dishwasher fills and drains repeatedly
I would check the drain itself. Make sure there aren't any eating utensils getting caught in the drain area.
9/30/2023 4:45:37 AM • Samsung... • Answered on Sep 30, 2023
Samsung DW80j3020US Dishwasher. It has no power to the power button. The control panel looks good.
Question edited for clarity. Question moved to maker category. Try these.
How to reset your Samsung dishwasher
Samsung https://www.samsung.com > answer > ANS00087943 Hold Smart Control until AP displays (about 3 seconds). · Hold Hi-Temp Wash until the dishwasher chimes (about 7 seconds). · Turn off the dishwasher.
Samsung Dishwasher won't start
Repair Clinic https://www.repairclinic.com > RepairHelp > Samsung... The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. More plus videos. https://www.google.com/search?q=Samsung+DW80j3020US+Dishwasher.+It+has+no+power+to+the+power+button ..
8/25/2023 2:53:23 AM • Samsung... • Answered on Aug 25, 2023
Samsung DW80F800UWS/AC 5E Error - fixed - now oE error no water
hello inspect the float switch it might prevent the dishwasher from filling with water if its malfunctioning or stuck
8/15/2023 8:34:07 AM • Samsung... • Answered on Aug 15, 2023
I need to replace the drain hose on a Samsung dishwasher code number DD68-00143A_MES Looking for a manual to get the correct part number!!
Try home depot they sell parts you can order them in the store .
4/25/2023 7:07:11 PM • Samsung... • Answered on Apr 25, 2023
How to turn off delay start on my samsung dishwasher model number DW80H994
a manual reset if the 'Delay Start' feature has been activated.. by turning off power by unpluging it or off at the breaker for 30 seconds.
4/1/2023 8:05:01 PM • Samsung... • Answered on Apr 01, 2023
Samsung dishwasher stuck in drain cycle eaven with door open and normal and heavy lights blinking
If your dishwasher is stuck in the drain cycle and the lights are flashing, it may be due to a faulty drain pump. You should check the drain pump and hose for any blockages or clogs. If these parts are clear, then the next step is to check the wiring between the dishwasher and the drain pump. If there is a loose wire or a broken connection, then this could be causing the issue. If the wiring seems fine, then the issue may be with the control board or the drain pump itself. If this is the case, then you will need to replace either of these parts to get your dishwasher back to working order.
2/22/2023 7:08:26 PM • Samsung... • Answered on Feb 22, 2023
The third rack on my Samsung dishwasher no longer pulls out all the way.
It sounds like there may be an obstruction in the glide track that is preventing the third track from moving freely. Here are some steps you can take to try and resolve the issue:
  1. Check for obstructions: Take a close look at the glide track where the third track is getting stuck. Look for any debris or objects that may be blocking the track. You can use a flashlight to help you see better. If you find any obstructions, carefully remove them.
  2. Clean the glide track: Even if you don't see any obstructions, the glide track may be dirty or have accumulated debris. Clean the glide track with a soft cloth and a non-abrasive cleaner to remove any buildup that may be causing the third track to get stuck.
  3. Lubricate the glide track: If the glide track is clean and free of obstructions, it may need to be lubricated to help the tracks move more smoothly. Use a silicone-based lubricant, such as WD-40 Silicone Lubricant, to lubricate the glide track. Apply a small amount of lubricant to the track and use a soft cloth to spread it evenly.
  4. Check the glider tracks: If the above steps do not resolve the issue, the glider tracks may be damaged or misaligned. Check the glider tracks to see if they are bent or damaged in any way. If so, they may need to be replaced. If the glider tracks are misaligned, adjust them so that they are straight and parallel to each other.
If none of these steps resolve the issue, it may be worth consulting with a professional technician or contacting the manufacturer for further assistance
2/17/2023 2:26:17 PM • Samsung... • Answered on Feb 17, 2023
2answers
The lower spray arm in my Samsung dishwasher is getting stuck on the lower basket somehow and not turning during wash, is there a way to raise the lower basket a little??
The clearance is governed by two things The height of the shelf and the height of the spray bar. Pull out the basket and check the screws holding the rails to the body. Remove the spay Bar and check the bushings and whatever dictates the height. It should spin, but shouldn't wobble.
2/12/2023 1:41:24 PM • Samsung... • Answered on Feb 12, 2023
Samsung Dishwasher '0C' error during wash cycle.
11/30/2022 12:54:35 AM • Samsung... • Answered on Nov 30, 2022
Samsung dishwasher dw80h9930us diagnostic mode e3
Hey Randy, thank you for the query. According to my research the E3 error code means that your dishwasher is unable to fill with water. To fix this problem, turn the water supply off and unplug your dishwasher from the power socket. You can then remove the water hose and check the water inlet valve to ensure it's working correctly.
9/25/2022 6:09:06 PM • Samsung... • Answered on Sep 25, 2022
How to unlock Samsung Dishwasher DW60A8050FG
Duplicate post deleted. Refresh the page to see your question posted. Try a reset https://www.samsung.com/us/support/answer/ANS00087943/ Videos as well https://www.google.com/search?q=unlock+Samsung+Dishwasher+DW60A8050FG ..
8/7/2022 3:44:04 PM • Samsung... • Answered on Aug 07, 2022
2answers
My Samsung DW7933 doesn't fill. turn it on, it sounds like its filling, the lights are on the control panel yet nothing happens. No water goes in, the lights stay on, and ...nothing. Any ideas?
If the water valve is clogged or defective, water will not flow into the dishwasher. Water inlet valves are not repairable—if the valve is defective, you must replace it. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve.
7/26/2022 8:29:27 AM • Samsung... • Answered on Jul 26, 2022
Samsung DHT400RHS over water level
7/20/2022 7:31:27 AM • Samsung... • Answered on Jul 20, 2022
Samsung DMR78AHS 6 Cycle Stainless Dishwasher, 6-layer insulation reduces sound, triple filtration prevents residue build up, eliminate pre-rinsing Logo
3 questions posted
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Samsung Dishwashers
  • Samsung Dishwashers
Most Popular Question
samsung dmr78 dishwasher will drain
  • Dishwashers
