20 Most Recent Whirlpool 24 in. DU930PWP Built-in Dishwasher Questions & Answers
Nothing lights up or runs
Take off the front lower panel with a screwdriver. After dishwasher is unplugged, open up the junction box with a screwdriver. If the cord was under-sized, it may have burned up on the black wire. This just happened to me. Dishwasher stopped mid-cycle and then there was no power. Needs a higher gauge cord. Was 16/3. Needs 14/3.
10/11/2011 1:04:11 AM • Whirlpool 24 in.... • Answered on Oct 11, 2011
Won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
11/9/2010 5:06:39 AM • Whirlpool 24 in.... • Answered on Nov 09, 2010
Stuff comes out not clean after entire cycle
is it heat up if not replace the heat element
10/18/2010 2:39:58 AM • Whirlpool 24 in.... • Answered on Oct 18, 2010
My dishwasher is a Whirlpool Model # DU930PWKQO.
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
10/7/2010 1:48:19 AM • Whirlpool 24 in.... • Answered on Oct 07, 2010
Whirlpool diwasher adg 9142
Check the inlet strainer at the bottom of the machine for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/21/2010 5:01:40 PM • Whirlpool 24 in.... • Answered on Sep 21, 2010
Hi. my problm is it will not drain the water my
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
8/24/2010 3:12:45 AM • Whirlpool 24 in.... • Answered on Aug 24, 2010
My dishwasher did not come with power cord. what
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
6/13/2010 1:03:59 PM • Whirlpool 24 in.... • Answered on Jun 13, 2010
My dishwasher DU930 will not pump out the water.
The clog is usually in the check valve if it is in the machine. The most common place for a clog outside the machine is the connection to the disposer under the sink if it has a disposer.
I have included a couple of pictures here, the first shows the pump assembly with the arrow pointing to the check valve, this valve is visible from under the dishwasher by taking the toe panel off. The check valve will unscrew but beware water will come out so have some towels ready.
The second picture shows a breakdown that will aid in getting the balls back in the proper place, the link is the service manual for the pump.
Let me know if you have questions.
Service Manual
Phil
6/2/2010 6:53:19 PM • Whirlpool 24 in.... • Answered on Jun 02, 2010
Whirlpool Dishwasher---All Dishes Finish With Cloudy Film
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
5/26/2010 5:34:47 PM • Whirlpool 24 in.... • Answered on May 26, 2010
Dishwasher not starting
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
1/18/2010 3:08:37 PM • Whirlpool 24 in.... • Answered on Jan 18, 2010
The lights go on like its going to start and then die
Sounds like a relay problem. It may need replacing
1/7/2010 12:17:25 AM • Whirlpool 24 in.... • Answered on Jan 07, 2010
Regular cycle no longer cleans well
Thanks for the clarification (we get a lot of people on here that don't know how to really use a dishwasher).
Sounds to me like the DW may need a through going over.
Confirm the make and model of the DW so I can see how it's built. I am suspect that with all the food particles and film you mention, that the spray heads are clogged in the spray bars, and, check that the drain hose is not kinked, and it's attachment into the garbage disposal is clear. I've had these clog before, limiting the ability of the DW to get rid of the dirty water.
12/17/2009 4:16:04 PM • Whirlpool 24 in.... • Answered on Dec 17, 2009
My dishwasher made some really
One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of metal...you guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
WLP seal tool helps center and install the pump seal
Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...carefulnot to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. -------
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
10/27/2009 5:14:38 PM • Whirlpool 24 in.... • Answered on Oct 27, 2009
My whirlpool model # DU943PWKQO has power to it, but no power
There is a thermal fuse in the top right corner of the control panel that will need to be replaced.
10/27/2009 4:15:43 PM • Whirlpool 24 in.... • Answered on Oct 27, 2009
Water stay in the dishwasher,don't exit
DU930 is not draining water out
9/8/2009 4:45:49 PM • Whirlpool 24 in.... • Answered on Sep 08, 2009
Water drains out during wash cycle
it's being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
8/17/2009 2:40:50 PM • Whirlpool 24 in.... • Answered on Aug 17, 2009
Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
Popular Tags
43 questions posted
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
dishwasher did not come power cord
  • Dishwashers
