20 Most Recent
Kenmore HE2t 3.7 cu. ft. Front Load Washer Questions & Answers
Lights flashing during cycle
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreenIf helped click helped.
Leaking hose part no. 1344559
if is leaking by the hose repair or chage and adjust very well the clip or replace because loose the pression.God bless you
Wash Cycle will not start; add garment and door locked lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
