20 Most Recent
Electrolux Eiflw55hiw Front Load Washer eiflw55hiw Questions & Answers
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
My Electrolux washing machine is blinking red with no time separator, can you help diagnose the problem. my model number is EWM09312
Here are some steps you can follow to try and identify the issue:
Check the Door: The start button on your Electrolux washer may start blinking if the door to the washer is not closed properly. Try opening and closing the door again to see if the button stops blinking.
Error Code Display: If the light only appears red, you can try the following manipulation to display the error code:
Turn on your washing machine
Simultaneously press the start button and the one to its left, usually the "end of cycle" button
After a few seconds, the error code should be displayed
Service Manual: For a more comprehensive diagnosis, you might want to refer to the service manual for your specific model.
It contains a guide to diagnostics of electronic controls and troubleshooting based on alarm codes.
ELECTROLUX EWM09312 SERVICE MANUAL Pdf Download ' ManualsLib
Technician may have to replace PCB.
Wtat is the dr code error?
Hello Aung, I appreciate your post!
Based off what you have described your Electrolux washer is displaying an error code of "DR". The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. You should perform a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Electrolux EWF 1486 HDW washing machine stopped working, what to do?
first test outlet to mke sure ur getting full voltage
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating
If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
HYPERLINK "https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help" https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
I have an Electrolux pedestal that the drawer won't latch. The model# is EPWD15SS1. What would be the part number for the strike and latch?
As of my last knowledge update in January 2022, I don't have real-time access to specific part numbers for appliances. However, I can guide you on how to find the part numbers for the strike and latch for your Electrolux pedestal.
- Check the Electrolux Website:
- Visit the official Electrolux website or the support section.
- Look for a "Parts & Accessories" or "Service and Parts" section.
- Enter your model number (EPWD15SS1) to find a parts diagram or list for your specific appliance.
- Contact Electrolux Customer Support:
- Reach out to Electrolux customer support directly. They can provide you with information on the parts you need.
- Have your model number (EPWD15SS1) ready when contacting them.
- Appliance Parts Retailers:
- Check with authorized Electrolux parts retailers or appliance parts stores. Many of them have online platforms where you can search for parts using your model number.
- Appliance Repair Centers:
- Local appliance repair centers may be able to assist you in identifying and obtaining the correct latch and strike for your Electrolux pedestal.
- User Manual:
- If you still have the user manual that came with your Electrolux pedestal, check the manual for information on replacement parts, including part numbers.
Remember to double-check the compatibility of the identified parts with your specific model EPWD15SS1. Model numbers and part designs can vary, so it's crucial to ensure that you get the right components for your appliance.
If you're unable to find the information online or through customer support, contacting a local appliance repair professional or a certified Electrolux service technician may be beneficial for assistance in identifying and obtaining the correct parts.
Electrolux washing machine EWT904
i kindly recommend inspect the control board for any burnt components, damaged traces, or any signs of damage
a;so ,check all the connection between the control board,display unit, and control panel, display unit are secure.
I have an Electrolux EWF1083 Front Load Washing Machine.
Did you try a power reset. Disconnect from the mains for 15 minutes. Press and hold the On button for 1 minute. Plug back in. It sounds like a control board issue. They are expensive, so professional diagnosis is advisable.
Also this is a possibility
Electrolux washer model EFLS517STT0 with errors e59, e11 and e41
The three error codes that you have received on your Electrolux washer are related to different components and functions of the machine, and they may or may not be related to each other. Here's what each error code means:
- E59: This error code indicates a problem with the motor tachometer, which is responsible for monitoring the speed of the drum during operation. This error could be caused by a faulty tachometer, a wiring issue, or a problem with the main control board.
- E11: This error code is related to the door lock mechanism. It indicates that the machine is having trouble locking or unlocking the door. This error could be caused by a faulty door lock switch or wiring issue.
- E41: This error code is related to the control board. It indicates that the machine is not communicating properly with the control board. This error could be caused by a faulty control board or wiring issue.
These error codes may or may not be related to each other, but they all could be caused by a problem with the main control board. However, it's also possible that each error code is related to a different component or issue.
To troubleshoot the problem, you may want to start by checking the wiring connections for each component mentioned in the error codes. If the connections appear to be fine, you may need to test each component individually to determine which one is causing the issue. If you're not comfortable doing this yourself, it may be best to contact a professional appliance repair technician for assistance.
How to enter diagnostic mode on Electrolux ewmgd70jppo
Please follow these procedures to activate the diagnostic mode on an Electrolux EWMGD70JPP0 dryer:
Ensure that the dryer is unplugged from the power source and turned off.
The "CANCEL" and "START" buttons should be pressed and held simultaneously.
Reconnect the dryer's power while continuing to hold down the "CANCEL" and "START" buttons.
Holding the "CANCEL" and "START" buttons together will start the diagnostic test.
That should only take a few seconds.
Once the diagnostic test has begun, let go of the "CANCEL" and "START" buttons.
Now that you should be in diagnostic mode, you can go through the various tests using the display.
The "CYCLE SELECT" knob and the "OPTIONS" button should be used to cycle through the tests, respectively.
The diagnostic mode should only be used by those who are qualified to work on appliances, as it is designed for service technicians.
It is advised that you get in touch with a reputable appliance repair provider if you are unfamiliar with the diagnostic mode or are unclear on how to proceed.
Electrolux Ecovalve EWF1087 wont progress past wash
If the machine is not progressing past the wash cycle and is stopping at the end of it, there could be a few possible reasons for this. Here are some troubleshooting steps you can try:
- Check the water inlet valve: If the water inlet valve is faulty or clogged, it can prevent the machine from progressing to the rinse cycle. Check to ensure that the water inlet valve is clean and functioning properly.
- Check the drain pump: If the drain pump is faulty or clogged, it can cause the machine to stop at the end of the wash cycle. Check to ensure that the drain pump is clean and functioning properly.
- Check the door latch: If the door latch is not engaging properly, it can prevent the machine from progressing to the rinse cycle. Check to ensure that the door latch is clean and functioning properly.
- Check the pressure switch: The pressure switch detects the water level in the machine and signals when to advance to the next cycle. If the pressure switch is faulty, it can cause the machine to stop at the end of the wash cycle. Check to ensure that the pressure switch is clean and functioning properly.
If none of these troubleshooting steps work, it may be best to contact a qualified technician to diagnose and repair the issue.
