20 Most Recent
HP ProLiant ML150 G3 Server Questions & Answers
ML150
See attached.
HEADS-UP: Per that page, it appears that some kind of HP account "entitlement" is required as per this text: "BIOS (Entitlement Required) - System ROM (1)"
Clicking the download link does indicate that a login is required:
Support validation required
An active warranty or support agreement covering HP Proliant servers must be linked to your HP Support Center profile to access this BIOS.
Help about access to BIOS for HP Proliant servers
At this site, we should not be expected to hunt for 'alternate' sources to obtain proprietary data. You will need to figure this out on your own from here.
This issue is CLOSED.
Dell RAID controller in HP server?
This particular device will require drivers for the Operating System to use. Also the hard disk drives will have to be installed an initialized outside the Operating System first before use. This is usually during startup after the system BIOS.
The exact steps can be found on the RAID card manufacturer's web site.
When i repair my windows at my server (HP ML150 )
reboot, and check to see if BIOS 'sees' the hard drive...if bios lists the drive, right click on 'My Computer' and select manage drives. the interface there is pretty straight forward... if bios does NOT see your drive, check your pin settings, be sure your connections are tight ...and check the BIOS settings match your drive
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Instalation of windows server edition
You have to make a floppy disk with the raid drivers on it. Start the Setup process and just as it's beginning it will ask you to hit F6 to install raid drivers. Hit F6, insert the floppy, install the drivers.
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum
that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum
and never told PC model sure.
so windows sounds work in the test in control panel
yes !
the, MP3 is complex, it can be from high data rate, source
and will not play unless converted .
one thing to try is use this free app
called Audacity
https://www.audacityteam.org/
then play it or convert it
or buy a USB sound dac that can decode any sound file on earth
or learn to test you PC first
windows sounds work
then in google type
simple MP3 sound test
https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/
works good above so your MP3 is no good or wrong bit rate.
if fails yours only , buy new DAC USB dongle now it plays them all
if windows sounds are dead the sound driver is missing
or on a server there is no sound chips oops. buy the DAC dongle.
if only 1 MP3 fails out of 100's find a better one or buy a DAC.
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
No servers, cant get mail or send mail cp was
If you lost everything then you've obviously reloaded all your software for the server, now you need to load your daily backup tapes onto the server so you can have mail again. you will also need to know all of your DNS's and you MX records if you're running exchange and if you don't know how to do any of it, then my suggestion is to hire a network administrator and it'll cost between $1k - $1.5k by time he's done bringing your system back online.
