20 Most Recent Sony VAIO E Series SVE15115FXS Laptop Questions & Answers
2answers
Unable to write bootable iso image on pendrive, Write method changed after selection of iso
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB. 1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command: DISKPART and hit enter. LIST DISK and hit enter. Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do. SELECT DISK 1 (Replace DISK 1 with your disk number) CLEAN CREATE PARTITION PRIMARY SELECT PARTITION 1 ACTIVE FORMAT FS=NTFS (Format process may take few seconds) ASSIGN EXIT Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands: D:CD BOOT and hit enter. Where "D" is your DVD drive letter. CD BOOT and hit enter to see the below message. BOOTSECT.EXE/NT60 H: (Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB. You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature). Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drivehope this helps
8/31/2022 10:12:12 PM • Sony VAIO E... • Answered on Aug 31, 2022
Dvd freezes up
Always don't play directly dvd in drive,first copy source to the pc and play i will increase the Lens lifetime.
2/18/2014 8:16:53 AM • Sony VAIO E... • Answered on Feb 18, 2014
New Sony Vaio laptop cannot fully install Sim City 3. Gets as far as message which reads "processing large file, please wait. Waited on several occasions for hours and hours, furthest so far is 40 per
may be to big of a game for the computer to load so it will take very very long or you wont be able to get it on that computer
3/24/2013 2:06:54 PM • Sony VAIO E... • Answered on Mar 24, 2013
The cylinder icon is constantly blinking yellow. Is this normal?
That would be your HDD.
12/13/2012 7:28:55 PM • Sony VAIO E... • Answered on Dec 13, 2012
Ever since I attempted to change the microphone levels and boost it started making a static noise when i webcam. I already change it to original setting but it is still making a noise.
Simply go to My Computer, Right Click, select Manage, and then device manager, right click on your device name and then uninstall it. Then go to the top and click Refresh or F5 and let the windows o/s install the driver again. Restart your computer and it shall be fine.
10/29/2012 7:24:14 AM • Sony VAIO E... • Answered on Oct 29, 2012
Disk drive keeps opening
You may have a virus or trojan lerking in the system, run a full scan of your computer and go to www.download.com type malwarebytes anti-malware and install, again run a full scan.
6/20/2012 10:25:23 AM • Sony VAIO E... • Answered on Jun 20, 2012
Cant get on sony acid music studio 5.0 cause i dont have my serial number anymore please help
We can't helpwith that but you could contact your software supplier and ask for a copy.
4/10/2024 11:55:56 AM • Sony Computers &... • Answered on Apr 10, 2024
Sony Vaio PCG-9S1L. Can anyone upload the owner manual. Thanks
Question edited for clarity, and toss in CAPS. Duplicate question deleted. Refresh page to see your question. Whatever you are trying to do with this Mr Chan, you are wasting your time. It is a Vintage computer running Windows 7. The manual is here
Sony VAIO PCG series Manuals
ManualsLib https://www.manualslib.com > ... > Laptop We have 1 Sony VAIO PCG series manual available for free PDF download: User Manual. Sony VAIO PCG series User Manual (202 pages). https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual ....
4/6/2024 7:02:02 PM • Sony Computers &... • Answered on Apr 06, 2024
Sony VRD-MC1 DVD RW Dual Layer. I have been using it many years, but have problems. What do I have to do now please?
Question edited for clarity and made into written English. If you got 6 to 10 years use, you just buy a new one for $15.97. https://www.google.com/search?q=Sony+VRD-MC1+DVD+RW+Dual+Layer ..
10/26/2023 1:10:51 AM • Sony Computers &... • Answered on Oct 26, 2023
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off. These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
9/18/2023 2:00:07 PM • Sony Computers &... • Answered on Sep 18, 2023
Where can I get Sony Control Cables needed for ST-S101 & TA-F101r?
Depending on your location. You have to go to a computer accessories closest to you. Yes you can definitely get it.
7/22/2023 7:40:47 PM • Sony Computers &... • Answered on Jul 22, 2023
Sony sound forge pro 11.0 serial number
Magix can supply you with that.
SOUND FORGE Pro - Download music editing software free
Magix https://www.magix.com > music-editing > sound-forge... SOUND FORGE Pro enables professional audio editing at the highest level. Download the music editing software now for free! ..
7/9/2023 6:13:23 PM • Sony Computers &... • Answered on Jul 09, 2023
I need an amplifier board for my Sony HCD-GNV111D / MHC-GNV111D
this is a question and answer forum manufacturers do not read this forum. You may want to look on eBay or other places that sell parts.
6/28/2023 3:26:24 PM • Sony Computers &... • Answered on Jun 28, 2023
Sony Vaio VGC-LM1E Recovery reinstall
Windows Vista Home Premium? It is an antique, throw it out! That is the most hated version of Windows ever produced. Your old hard drive has an embedded serial number and that is part of the credentials used to load your original copy of Windows and authorize the copy. However, that should come later when you enter the Product ID did you format the hard drive first? format C:\ /s if I remember correctly at CMD Prompt Your question is at Tom's Hardware! https://www.google.com/search?q=Sony+Vaio+VGC-LM1E+install+and+format+hard+drive ..
5/30/2023 8:30:03 PM • Sony Computers &... • Answered on May 30, 2023
Why can't Alexa change my TV channel with Sony Basic TV app?
Not sure who you are talking to in the 'Additional Information' box below your question. You may have be talking to an AI Answer Bot which has had its answer deleted. That box up there is for Experts to ask you for further information before committing to an answer. The correct way is to click Comment under the Answer you are replying to. Sony seems to think it can be done.
Connect your TV to the Amazon Alexa app
Sony https://www.sony.ca > electronics > support > articles On the Amazon Alexa app: Open the Amazon Alexa app on your smartphone, search for BRAVIA, and then select Sony's TV - Basic Skill and enable it. Note: If you ...
FAQ - Control your TV with Amazon Alexa devices
Sony https://www.sony.com > electronics > support > articles For TVs with the TV Control Setup with Amazon Alexa app: Select the Sony's TV - Basic skill, and enable it. Alternatively, you can also enable it by ...
5/16/2023 4:39:29 PM • Sony Computers &... • Answered on May 16, 2023
2answers
Need to reset password for SONY VAIO PCG-7142L.
Solved - password reset or removal
Vista Forums https://www.vistax64.com > ... > General Discussion Its a Sony laptop with a windows vista home premium OEMAct, model pcg-7142l . I don't know if it is a bios or vista password.
How to remove the log in password.
Sony https://www.sony.com > electronics > support > articles Nov 17, 2016 - Refer to the operating instructions supplied with the computer for model-specific information required to complete a format and recovery ...
How to Reset Password on Sony Vaio Laptop Windows 7/8 ...
PassCope https://www.passcope.com > how-to-reset-password-o... Here, we are going to specify how to reset the password on Sony Vaio laptop using various alternatives for Windows 7/8/8.1/10.
5/9/2023 8:17:20 AM • Sony Computers &... • Answered on May 09, 2023
Need a manual to fic my mini sony CR-120
https://www.manuals.co.uk/sony/dcr-pc120e/manual
3/22/2023 8:41:45 PM • Sony Computers &... • Answered on Mar 22, 2023
Sony VAIO E Series SVE15115FXS Laptop Logo
Popular Tags
17 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Computers & Internet
Most Popular Question
new sony vaio laptop cannot fully
  • Computers & Internet
