20 Most Recent HP Colour Laserjet Cp3505 Laser Printer 3505 Cb441a Questions & Answers
Try these steps to resolve paper jam issues:
HP Office... | Answered 16 hours ago
I want to give a solution about your problem about turning on wireless radio feature on your hp officejet pro 8620 printer.
The solution is just download HP ePrint Software. You can download at link below
HP Officejet Pro 8620 Driver
Pull the plug out and put it back in
HP Office... | Answered 2 days ago
You will need to take the side panels off to get to the circuit boards. The Main board is often on the right hand side when looking from the front
It is probably a broken gear tooth in the FUSER
HP Office... | Answered 3 days ago
There will be one of several micro switches that detect when various doors hatches and flaps are open or closed. These are usually recessed behind small slots in the casing. Each will have a corresponding spike or flange on the appropriate door hatch etc. carefully examine each of the movable pieces and look for evidence of a small piece that may have broken off or a "socket" that does not have a "plug" to fill it. Test these by carefully feeding a non-conductive probe (just in case) into the port and feeling for a little bit of springy resistance. If you find one, fold some light card into a tube that fits snugly into the hole and depresses the switch. Close everything up and try the machine. Hopefully you will find the missing link, then it is just a matter of making a semi permanent plug that you can remove when you need to.
HP Office... | Answered on Mar 18, 2019
Go to your printer settings on the PC control panel (or equivalent subject to OS) and find printer properties, then find device settings. Check that Tray three (and others) are "not available" and or "not installed" preferably both.
The paper tray does not spring up until the tray is loaded into the machine.
Check your software and drivers. It may be that the ipad ios driver set is specific for photo printing only.
Hp printer is a very common printer in the world of printers. There are many benefits of hp printer such as digital print, graphic prints, copy, fax and many more. There are many errors may be generated while using a printer then call at hp printer phone number 1-888-315-9712 and resolve your common errors. http://printer-help-number.com/hp-printer-support
I am not using this printer but try to check for right arrow(ins) option which will take multiple scans into a pdf.
OFFICEJET
HP Office... | Answered on Mar 14, 2019
Problems with cartridges recognition?
press left arrow, cancel, left arrow. Then you can reset the printer. It works really well for the HP photosmart b110a.
You have a problema related with the Fuser Unit, you may try to replace the Heating elemento or replace the entire Fuser
HP Colour Laserjet Cp3505 Laser Printer 3505 Cb441a Logo
2 questions posted
Clive
Clive
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
main inner paper tray says needs
  • Office Equipment & Supplies
