20 Most Recent Whirlpool AWM6141/1 Front Load Washer Questions & Answers
Could be due to a trip off in the control board , it can also be related to an error in the program, the inlet water flow or the drive.
Remove and check water line, check the voltage at the sequential cycle of the program , is absent then the program controller is faulty.
Whirlpool... | Answered on Jan 16, 2013
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Whirlpool... | Answered on Mar 25, 2011
Your machine should have a lower front panel attached below the door. This would be a full width panel that goes from the floor up to almost the bottom of the door. Unplug the machine. Remove this panel with 3 or 4 screws. The pump is behind this panel, facing forward. The pump has a twist plug clean out. Use a shallow baking pan to catch the small amount of water that will come out of the pump when you open the twist plug. After cleaning the pump, assembly is the reverse of what you just did.
Good luck.
Whirlpool... | Answered on Jan 30, 2011
take out door switch and tape the two wires together, if the washer works fine this way, then the door switch is bad. if the door switch fails it cuts electricity off to motor.
Whirlpool... | Answered on Jan 14, 2010
Hi There
I have found this for you to read and hope this is helpful. Let me know how it goes.
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.Thank you for writing to fix ya.
Best Regards Richard
Whirlpool... | Answered on Jan 07, 2010
sounds to me like the door isn't latching properly therefore it will not start or advance on any cycle. check this out.
Whirlpool... | Answered on Oct 26, 2009
F9 is a water pump problem, either clogged pump, or pump malfunctioning, Check for something clogging the water pump
also there may be water and air stuck in the pressure switch tip
Whirlpool... | Answered on Jul 30, 2008
To remove the code, press pause or cancel button twice and the power button once. If the code is still displayed, unplug the washer or disconnect the power for one minute. Items were detected in the washer during the Clean Washer cycle. Remove items from the drum and restart the Clean Washer cycle.Jun 13, 2019
Error Codes in Front Load Washers - Whirlpool Home Appliances
https://producthelp.whirlpool.com > Washers > Washer_Product_AssistanceSearch for: How do I clear the error code on my Whirlpool washer?
Whirlpool... | Answered on Oct 12, 2019
sounds like the motor or clutch pack is bad if so its a expensive fix
Whirlpool... | Answered on Oct 05, 2019
Unplug washer for 30 minutes. Plug back in se if opens. If not take off top panel off washer. There is a latch to release door.
Whirlpool... | Answered on Oct 03, 2019
Whirlpool AWM6141/1 Front Load Washer Logo
21 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
door light come after starting stops
  • Washing Machines
