20 Most Recent
Polaroid FLM-153B 5 in. LCD Television Questions & Answers
No picture bu sound is available, runs for some
Tv have a long board that call the LCD inverter board,this board is dead.This long LCD inverter board only job are to to provide the tv LCD screen panel to have a backlight to the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
4/11/2011 12:02:49 AM •
Polaroid...
Answered
on Apr 11, 2011
I have a polaroid FLM153b
Hello, the picture disappears after a little while, sound still available, in rest its flickering
4/10/2011 11:53:30 PM •
Polaroid...
Answered
on Apr 10, 2011
Tv codes
go to the partstore.com , sign in as guest and put your model tv in and will give a list of items associated with your tv
4/12/2009 7:56:47 PM •
Polaroid...
Answered
on Apr 12, 2009
Is a FLM-153B a digital tv
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
This is the sort of thing a lot of people are wondering
lately. the answer is no. you'll need a converter. the picture
quality is 1080i and 720p so it is an HD display, but it has a standard tuner
built into the unit also called NTSC - the old broadcast standard. to get a digital picture on that TV
you'll need an ATSC tuner. you can buy one that plugs into your TV. The US government
is offering rebated on digital converters which is a good option. check http://www.dtv.gov/
You can buy digital connectors and digital cable at most retails stores to hook the equipment up.
-good luck-
Will
www.compressionconnector.com
2/20/2009 12:25:50 AM •
Polaroid...
Answered
on Feb 20, 2009
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
