20 Most Recent Acer AL2671W 26 in. LCD Television Questions & Answers
Scan doesn't work on Acer AL2671W
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
8/16/2017 2:57:47 PM • Acer AL2671W 26... • Answered on Aug 16, 2017
My Dad has same problem with Acer AL2671W stuck in standby.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
6/27/2017 5:35:27 AM • Acer AL2671W 26... • Answered on Jun 27, 2017
Remote issues with shaw cable box - volume, channel selection and power - how to sync the remote with the tv and/or shaw box/remote?
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
3/2/2015 4:30:36 AM • Acer AL2671W 26... • Answered on Mar 02, 2015
How do i solve the problem of my Qsat that moves channels and press menu on its own
Sounds like main system control memory IC fault. Contact any service technician. http://electronicshelponline.blogspot.com/
6/9/2014 3:31:45 AM • Acer AL2671W 26... • Answered on Jun 09, 2014
0answers
A coil inside the slide out tuner box is fried.
Tuner is faulty. [Shorted]. Contact any service technician, or the authorized service center. Gopakumar Gopalan Google
3/6/2014 5:59:32 PM • Acer AL2671W 26... • Answered on Mar 06, 2014
0answers
Moje lcd jen sviti orazova kontrolka pover co stim
If you're sound in electronic, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/29/2013 8:16:46 AM • Acer AL2671W 26... • Answered on Oct 29, 2013
Mam lcd televizi Acer AL2671w a sviti jen oranzove
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/29/2013 8:15:15 AM • Acer AL2671W 26... • Answered on Oct 29, 2013
ACER AT3201W TV At start up
ja sam morao promijeniti elektronicu.sad radi sve ok
8/16/2013 7:50:53 AM • Acer AL2671W 26... • Answered on Aug 16, 2013
No power on tv
Check its main power regulator board. It might need replacement. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
4/30/2013 7:26:11 PM • Acer AL2671W 26... • Answered on Apr 30, 2013
Acer AL2671W wont turn on
Sounds like a problem with the power supply board, typically power surges will cause fuses and capacitors to blow. If you go to tvrepairkits .com you can find a power supply kit with instructions that will allow you to repair this problem yourself. They also have coiled solder which works really well...hope this helps.
10/22/2012 8:40:25 PM • Acer AL2671W 26... • Answered on Oct 22, 2012
4answers
TV losing its channel memory
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
5/8/2012 9:05:55 PM • Acer AL2671W 26... • Answered on May 08, 2012
8answers
This too was my problem... ended up googling my heart out trying to find the solution to this problem and found a blog posting
"AL2671W Stuck in Standby Hey - I fixed a TV! It' s been a long time actually since I did something useful for someone. I got asked to look at an Acer AL2671W LCD TV. Bought for about £500 five years ago, and that was cheap then, recently it has regularly refused to come out of standby. Now it is stuck in Standby and won't work. So where do you start? Google of course! Some results showed that this was a common fault on these TV's. One guy in a forum said 'easy fix, replace C280 100uF 16V on the main board'. Good enough of a clue to take a look. You have to firstly remove the SCART socket block before the back will come off and then the inner metal cover over the PSU, audio card and main card as mentioned before. It looks just like a mini ATX card. It is a multi layer, double sided PEC with surface mount and traditional components. Bad news though, no C280 to be found. I buzzed through the front power switch to check it wasn't stuck and traced the cabling to the socket on the main board. Very close by the socket is C380, this is an electrolytic 100uF 16V. Too much of a coincidence? Anyway worth a punt I thought so I changed it for an 100uF 40V I think it was and re-assembled the TV. It worked! the TV now comes out of standby and has been returned to its owners. Result! Posted by andychamb"
I end up finding an old ATI card (since it was unsupported with win7) that had the same value capacitor and replaced C380, located around the centre, bottom left corner (the left one). works like a dream.
3/5/2012 10:28:44 PM • Acer AL2671W 26... • Answered on Mar 05, 2012
0answers
Acer AL2671W 26 in. LCD Television Logo
122 questions posted
Top Acer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Televison & Video
Most Popular Question
acer al2671w stuck in standby
  • Televison & Video
