20 Most Recent
Xerox Phaser 6120/YN Laser Printer Questions & Answers
Error message imaging unit is out
Hi rmcday:
Here your problem.
The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following:
■ An OPC Drum
■ Waste Toner Assembly
■ Charge Roller Assembly
9.0 Consumables, Routine Maintenance Items and Options
Item Life based on 5% coverage Part No. Replaceable by
Black Standard Toner Cartridge
Black High capacity
3,000
7,000
106R00679
106R00684
User replaceable
Cyan Standard Toner Cartridge
Cyan High capacity
2,000
5,000
106R00676
106R00680
User replaceable
Yellow Standard Toner Cartridge
Yellow High capacity
2,000
5,000
106R00678
106R00682
User replaceable
Magenta Standard Toner Cartridge
Magenta High capacity
2,000
5,000
106R00677
106R00681
User replaceable
Imaging Unit 50,000 images 108R00593 User replaceable
Transfer Belt 50,000 images 108R00594 User replaceable
500-Sheet Feeder N/A 119650600
Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable.
Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced.
Hope this helps
Model: Xerox Phaser 6120. We
Hi there.
These toners normally has a metal contact that tells the printer that the toner is there or how much toner is left. Make sure that these contacts are clean and dry and free from any dirt or inks. Use a dry cloth to clean it.
Let me know if you need further assistance.
Thank you for using Fixya!
Will not pick up paper
Hi there clean the paper receiver roller and then reset the copier and try. Let me know whats happened. If not done then i am sure the sensor is damaged and you need to replace that.
I tried to update the
The firmware update didn't install correctly or was corrupted when you downloaded it. Download the update again and go through the install process again, that should resolve the issue.
Changing black toner
To change your toner first turn off the printer and unplug it from the power outlet. Then, lift the toner door. Carefully grap the toner cartridge from both ends and lift it up. Do not shake the toner as you may get dirty. Then take the new toner cartridge, remove any plastic covers and insert it in the printer. Close the toner door and start your pritner.
XEROX PRINTER PROBLEM FUSER TEMP.
Problem on fuser unite.When it hole surface block waste toner then arise this problem.Clean all surface and wast toner then solve your problem.
Ink
On the fuser (under the top cover), there are 2 green levers with envelopes on them. The one on the right is probably flipped up. The purpose of these levers is to decrease pressure on the paper when printing on envelopes which are 2 or 3 layers of paper. It reduces the wrinkling that occurs when printing envelopes on most laser printers. Flip that lever down and you're golden.
