20 Most Recent
Acer AL2216W LCD Monitor Questions & Answers
My Acer AL2216W monitor this
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Shadows around the objects
One common cause of ghosting is an inferior monitor cable. Remove any extension cables and check again. The monitor may be getting interference from another device nearby, such as a printer, for example. Try turning off/ disconnecting other devices and see if the ghosting disappears. If so, you could buy a better shielded cable, or rearrange your components to prevent the interference.
That would be a simple fix if it works....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Power
There are monitors which have their own power outlet and there are some which don't have any. If you are sure that the monitor doesn't have power outlet, then make sure that you press on the power button. Please send me the model name of your monitor so that I can take a look at it and tell you what to do next.David
I have same problem
Replace the following capacitors:
3 pcs - 220 microF - 25v
2 pcs - 1000 microF - 25v
1 pc - 2200 microF - 25v
Resolder the 2 transformer legs for the inverter.
Roan
Triangle Tech Whiz.
