20 Most Recent Hussmann Commercial Freezer DCCG-12 Questions & Answers
This unit has a crank case pressure regulator and
Freezers usually have a super heat of 6-8 degrees and as it approaches the set temperature, it can be as low as 4 degrees. you will have to 'babysit' this and adjust as you go but it has to be done in extremely small amounts. the crankcase pressure regulator basically keeps the compressor from being overloaded from high pressure like from after a defrost or the door being left open.
7/7/2017 11:14:26 PM • Hussmann... • Answered on Jul 07, 2017
What the fastest way in defrosting dairy cooler
http://www.hussmann.com/Installation%20Manuals/DCCG_DCSG_06_im.pdf See page # 6
10/20/2010 1:54:22 AM • Hussmann... • Answered on Oct 20, 2010
What the best way in defrosting evaporator when
10/20/2010 1:53:09 AM • Hussmann... • Answered on Oct 20, 2010
The freezer keeps turning off. Got any
Check the time clock.
8/23/2010 12:24:47 AM • Hussmann... • Answered on Aug 23, 2010
What horsepower is a Hussmann compressor model
3/4 horse.
7/26/2010 3:28:18 AM • Hussmann... • Answered on Jul 26, 2010
Had theoverload and relay switch replaced still tripping breaker
yes. if you pull all the wires from compressor and use a meter with a continuity bell , touch a copper line and then a compressor terminal. try em all. odds are you'll hear a bell showing continuity or the fact that power can flow directly from the compressor terminal to the chassis= a grounded compressor. or you could have a dead short where the wires in to the compressor aren't touching the case but are touching each other before they go to the motor windings, = a short. either one is an all done situation. time for new .
11/21/2008 2:05:06 AM • Hussmann... • Answered on Nov 21, 2008
Hussman DCCG Freezer
are they the florescent tube type?? i suspect that the ballast went bad
4/23/2008 3:24:51 AM • Hussmann... • Answered on Apr 23, 2008
Tripping Breaker
I have the same proublem with mine. It doesn't do it all the time but it does happen..
4/15/2008 6:36:29 PM • Hussmann... • Answered on Apr 15, 2008
Need to fix the ligts for the freezer two lamp were its located de ballast
it located normal freeze.
3/26/2013 2:28:44 PM • Hussmann... • Answered on Mar 26, 2013
Replaced cap tube and drier, vacuumed system, weighed in charge and still will not go bel 40 degreesow
Did you check the system for a restriction of any kind? Also, is the compressor working correctly? I'm assuming the reason you began working on the machine was because it wasn't freezing, but what was you steps in determining the problem to begin with. Please list what you did step by step so I can help. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6/22/2012 7:29:10 AM • Hussmann... • Answered on Jun 22, 2012
0answers
Hussmann Commercial Freezer DCCG-12 Logo
14 questions posted
Top Hussmann Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
View Most Popular
Hussmann Freezers
  • Hussmann Freezers
Most Popular Question
unit crank case pressure regulator
  • Freezers
