20 Most Recent McCall Freezer 7-7045FT Questions & Answers
Freezer will not pull down. sometimes does for a
My first question is, who worked on it before? you are discribing a moisture restriction. replace the drier again making sure you get ont that us sealed. Make sure you r hoses and msnifold dont leak by. Use a testo set or other trusted way to monitor your vacuum. Before you start vacuum, change oil in pump. I did not believe yhat nnade much ofca difference, til I tested it myself. And it does nnake a great big difference. Use only a trusted vacuum pump. Listen to the vacuum and shut off the manifold if you hear a different sound or yhe sound changes when the system us ooen vs the manifold closed keep pulling. When you hear no differance and your pump is in great shape its dry. Leave it on over night if you have to. Put a heat lamp on the inside to raise temp and make any water easier for the vacuum pump to pull out. maybe before you do this make sure ghe w bole system is tight pressure up to 200 lbs with dry nitrogen and let it set for 2 hours or more.
5/20/2019 3:03:15 AM • McCall Freezer... • Answered on May 20, 2019
Need to know the design
The McCall web site has nothing easily found on the 7-7045FT unit.
In answer to you questions, first, what is the expansion device. TXV, Cap Tube, or something else?
Low site pressure will be dictated by the super heat. The high side, in many cases, is usually ambient plus 30, then convert to psi.
Let me know if you need more info. And please double check the model number/ serial numbers.
good luck
6/23/2011 2:36:31 PM • McCall Freezer... • Answered on Jun 23, 2011
I need compressor for Mcalls
I have 1 Mc Call Freezer Model 7045 FT for and refrigerator 7045 FT for sale. TXT John 520-241-1207.
6/23/2011 2:31:33 PM • McCall Freezer... • Answered on Jun 23, 2011
Mccall stand up freezer Has been sitting for a
If the freezer was working fine before sitting for a while then you should replace the starting capacitor first.
If not work then other possible faults is leak of refrigerant. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.There are also many other things that can go wrong with your fridge and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way. There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly
9/27/2010 8:42:54 PM • McCall Freezer... • Answered on Sep 27, 2010
Freezer not freezing below or funtioning properly
You have to contact service center immediately.
6/11/2010 7:40:43 PM • McCall Freezer... • Answered on Jun 11, 2010
Condensor freezes up and freezer doesn't keep things frozen
its the evap coil from what your saying if its frost free its a defrost prob
5/26/2010 9:43:29 PM • McCall Freezer... • Answered on May 26, 2010
I have a freezer model# 7-7045ftc ive changed the
Hi. I don't have the 404 number but I do have the R-134 and the R-500 numbers.
R-134 at 75 Deg = 93.3.1 psi
R-134 is a HFC
R-500 at 75 Deg = 108.1 (Actually R-409B)
R-500 is a CFC
R-123 at 75 Deg = -12.7 (Minus)
R-123 is a HCFC
Not sure if this helps but should put you in the ball park.
Kelly
I know you said 22 Oz of 404. I add cooalnt until I get the high side numbers keeping in mind the system capacity....
Kelly
2/24/2010 2:18:54 AM • McCall Freezer... • Answered on Feb 24, 2010
3answers
Compressor failed replaced the entire
I have reviewed your problem and it seems to me, that your head pressure is a little to high as well as your suction side pressure being too low.
It may be that your system has not settled down and or may be overcharged or could be due to a restriction in the cap tube.
I'm sure that you pulled a long vacuum on the unit and dryers has been replaced.
If the unit has had a burnout, did you flush the system or just vacuum..
Hope this information has been of some help.
Please rate....
P.S. you know, it could just be that the oil has not completely settled, but should with system running for a few hours.
10/18/2009 1:12:15 PM • McCall Freezer... • Answered on Oct 18, 2009
Can not get temp. below +10 f
what is your superheat and is defrost cycle working
2/28/2009 4:14:28 PM • McCall Freezer... • Answered on Feb 28, 2009
I have a McCall 4-4070FC i need to find out how to turn on the Lights and Door Heaters?
Your light switch is white generally around frame... As for door heater it will be on as soon as you plug unit it. You can feel around door jam to see if heating... Should be warm not scalding hot. McCall was sold to manitowoc and some parts are no longer available. If you're able to do repair yourself try case parts.
12/10/2014 7:47:50 PM • McCall Freezers • Answered on Dec 10, 2014
0answers
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
2answers
Norfrost c6aew chest freezer compressor wiring
Hey. I dont suppose you figured out where the wires went all all? I've done the same thing ???? img-20240210-wa0019-hnmqxmichaytgjvoydy3hl3m-d-0.jpg img-20240210-wa0018-hnmqxmichaytgjvoydy3hl3m-d-1.jpg img-20240210-wa0020-hnmqxmichaytgjvoydy3hl3m-d-2.jpg
2/11/2024 12:01:33 PM • Freezers • Answered on Feb 11, 2024
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words. That is an overheating fault. Replace the fluff with no fluff. Make sure the condenser coils are free of dust and there is good airflow Or It is low on refrigerant gas and you need a service tech.. ..
2/3/2024 5:25:13 AM • Freezers • Answered on Feb 03, 2024
Cubic feet of a fridgeadare chest freezer- FFC13K2CW1
The Frigidaire FFC13K2CW1 chest freezer has a capacity of 12.8 cubic feet. More info: https://www.partselect.com/Models/FFC13K2CW1/
1/22/2024 2:51:52 PM • Freezers • Answered on Jan 22, 2024
McCall Freezer 7-7045FT Logo
Popular Tags
15 questions posted
Top McCall Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a McCall Freezer Expert? Answer questions, earn points and help others
View Most Popular
McCall Freezers
  • McCall Freezers
Most Popular Question
freezer will not pull down sometimes
  • Freezers
