20 Most Recent
Whirlpool GHW9250M Front Load Washer Questions & Answers
My Whirpool duet HT washer sometimes will not
There may be a senor that detects when the door isn't closed. It may be failing or mounted in a bracket coming loose. I had one that the bracket broke and sometimes it would start and other times it wouldn't. I rigged a new bracket and it works fine. You could also disable the sensor by shorting it, but you might have water leak out some day.
You will need to open the case to access the sensor.
2/1/2018 2:02:10 AM •
Whirlpool...
Answered
on Feb 01, 2018
Whirlpool cabrio wont fill
Inside the machine at the back are two water inlets that operate using a selennoid.
I would go to partselect.com and find your water inlet selennoids and replace them.
Before replacing them... use an Ohm meter and check to see if the windings are are open (Shorted)
If no meter is around, use a battery (1.5) and a LED and if the LED lights then you Don't need to replace. check both
The other problem would be a diaphram up in the controller about 4" disc with a small hose. This guy resets those selennoids.
Remove hose and blow into it. While blowing.. about 3" down pinch the hose and put in on the Diaphram. this usually resets the machine
4/9/2012 3:21:32 PM •
Whirlpool...
Answered
on Apr 09, 2012
Washer fills with hot water on cold wash or rinse.
typically hot is on the left and cold is on the right at the house faucets but in some cases they are reversed so if filling with a cold setting and the right side supply is hot the plumber reversed the lines when the house was built which while its semi rare has been seen numberous times
9/26/2011 8:42:53 PM •
Whirlpool...
Answered
on Sep 26, 2011
Hi
it is no power , the control panel is not
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong. Sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
8/24/2011 2:02:35 PM •
Whirlpool...
Answered
on Aug 24, 2011
Whirlpool Duet GHW925OMW2
The problems you're having stem from the CCU circuit board (inside machine, top, back, plastic case) there are bad solder joints (also called cold solder joints) on the circuit board where the spade connectors and relays (5 of them) are supposed to be securly soldered to the circuit board. The loose joints control the communications between the door lock (code FdL) the Motor control section (code F11) and the main circuit board. The cure is to remove the top of the washer then remove the CCU plastic case with the circuit board, it's easier that way, then remove the board and touch-up those solder points I mentioned. They're easy to spot, they are the biggest solder joints on the board. Remember to mark all the connectors, they are keyed but you should mark them anyway. If you're not up on soldering techniques, just remove the case with board and take it, along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
3/17/2011 11:45:35 PM •
Whirlpool...
Answered
on Mar 17, 2011
Whirlpool ghw9250mwo will not
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 2:00:49 AM •
Whirlpool...
Answered
on Oct 01, 2010
When the machine is off it is filling up with
It sounds like you're probably looking in the right place...it's possible that the inlet water valve is stuck open or simply defective. Turn off the water, turn off the power, remove the hoses and check the inlet valve. The valve could be stuck, have something in it. You may need to remove the inlet valve(s).
7/7/2010 2:57:01 AM •
Whirlpool...
Answered
on Jul 07, 2010
How do I turn off "CONTROL LOCK" light to get
Hi
Thanks
for using FixYa. Assuming that it is a Whirlpool Duet Washer you’ll need to press
and hold the END OF CYCLE SIGNAL button for 3 seconds. Please
do accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
6/18/2010 8:09:59 PM •
Whirlpool...
Answered
on Jun 18, 2010
How do I turn off "CONTROL LOCK" light?
Hi
Thanks
do rate the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
6/18/2010 7:49:20 PM •
Whirlpool...
Answered
on Jun 18, 2010
