20 Most Recent Evga nForce 680i SLI (122CKNF68) Motherboard Questions & Answers
0answers
Computer not turning on
open core voltage connection after if that power on
so problem in your motherboard vrm circuit goes off
1/15/2016 5:43:24 PM • Evga nForce 680i... • Answered on Jan 15, 2016
0answers
SL-K8TPro-939 double digit diagnostic LED codes
Did you add a card? Have a power spike?
3/28/2014 2:10:56 AM • Evga nForce 680i... • Answered on Mar 28, 2014
0answers
Nvidia nforce 680i sli 7F with no video.
The Nvidia GeForce 8800GTX graphics card, requires using TWO 6-pin PCI Express power cables,http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpressMINIMUM power requirement for using TWO 8800GTX's is;1) Using one 8800GTX requires a 450 Watt power supply.Must have a 12 Volt power rail capable of 30 Amp's.(If more than one 12 Volt power rail, add the amperage of all, to arrive at the total Amp's)Using TWO in an SLI mode requires 750 Watts minimum, and around 50 Amps.Let me ask a couple of questions;1) Does your Power Supply have the minimum required Wattage, and Amperage on the 12 Volt power rail? (Or rails)2) Are you using a Power Supply, that has FOUR 6-pin PCI Express power cables?http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress3) Looking at the adapter power cable, shown on the right side of the above link;IF, your Power Supply does Not, have the recommended amount of 6-pin PCI Express power cables; did you use -> TWO 4-pin Peripheral power cables, for -> EACH adapter cable?http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral(Mistakenly referred to as a 'Molex' power cable. Molex was the first to design the connector. Name kind of stuck, like calling a adjustable open-end wrench, a Crescent wrench)Why the line of questioning?Computer unplugged from power, Anti-Static Precautions FOLLOWED, remove the power cables from the cards.A) Is the connection end of either power cable burnt? (There should be FOUR cables) Look close.B) Remove the cards from the PCI Express x16 slots.Look down into the PCI Express x16 slots at the contact pins. (With a light) Burnt?How about the gold plated contact pins on the cards?There HAS to be TWO 6-pin PCI Express power cables, for EACH card.There HAS to be TWO 4-pin Peripheral power cables used for EACH 6-pin PCI Express adapter power cable.A 6-pin PCI Express power cable requires TWO 12 Volt wires. (Yellow)Using just one 4-pin Peripheral power cable will cause burning.Not right away. Takes time.Everything chilly? I'm 'barking up the wrong tree'?http://www.motherboards.org/imageview.html?i=/images/mobot/motherboards/10420.jpgOkay, now look at the capacitors on the motherboard. To the left of the Processor socket are 6 solid Polymer capacitors.If one of these babies is bad, YOU will know it. They explode.More of a concern is to look at the other capacitors. The Electrolytic Capacitors. More specifically, they are Radial Aluminum Electrolytic Capacitors,Example,http://www.panasonic.com/industrial/electronic-components/capacitive-products/leaded-electrolytic.aspxVisual signs of failure for bad Electrolytic Capacitors,http://www.capacitorlab.com/visible-failures/index.htmLOOK CLOSE. Use a light. A slightly bulged top, or a capacitor on a hard lean, may be hard to see if this is your first time.Everything 5by?Then your Power Supply cr@pped out.Each PCI Express x16 slot is capable of providing 150 Watts.Each 6-pin PCI Express power cable is capable of providing 75 Watts.[ PCI Express;http://en.wikipedia.org/wiki/PCI_ExpressScroll down, read under the bold subheading - PowerA LOT of power is required for the two cards alone, and I do not even know what mobo, processor, ram memory, fans, optical drive/s, and harddrive/s, you are running.Appreciate it if you would post back with your findings.Post in a Comment.Regards,joecoolvette
7/26/2012 7:41:21 AM • Evga nForce 680i... • Answered on Jul 26, 2012
Have an EVGA nForce 680i.
Hi.
The reason its only seeing just under 3GB of memory is no doubt because you are using a 32BIT operating system (probably XP).
If you were to install Win 7 (X32) or a 64BIT operating system the computer would see all 4GB of RAM you have installed.
Its nothing to worry about though as the computer will work just fine. If you were to check in the BIOS you would see all 4GB of memory is there and see by the BIOS.
Regards.
5/1/2011 4:45:23 PM • Evga nForce 680i... • Answered on May 01, 2011
I was watching a movie and the sceen went black i
If you are using a lcd monitor, it is very possible that your monitor backlight failed, have you tried connecting a different monitor to check your video adapter?
If the backlight failed, the image is on the screen, but is not visible unless you shine a light on to the screen
2/23/2011 5:45:47 PM • Evga nForce 680i... • Answered on Feb 23, 2011
Having problems at BOOT in a 680i SLI MB..... I
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
12/4/2010 10:45:11 PM • Evga nForce 680i... • Answered on Dec 04, 2010
1 long 1 short beep code, is it a motherboard
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM is securely seated try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
11/26/2010 10:46:52 PM • Evga nForce 680i... • Answered on Nov 26, 2010
My Evga 680i SLI
Does it successfully recognize one of the cards at least? Or when you have both plugged in, none work? Are you sure you are using the SLI connection cable / plug-in correctly, and have it plugged in all the way? Also are you certain your power supply is rated high enough and has all the correct power plugs necessary for such high end SLI?
If the answer is yes to all of the above, try swapping the cards positions, make sure both cards work individually and then we can go from there if need be.
Thanks, let me know Tim
9/24/2010 4:07:31 AM • Evga nForce 680i... • Answered on Sep 24, 2010
Post doesnt load after restart
may i have big problem in my computer some errer was start. when the screen was the blue and arre start and my speacer also do not give sound perfect so pleas give me a solution fast.
8/14/2010 3:22:48 PM • Evga nForce 680i... • Answered on Aug 14, 2010
Sound problem
Those noises indicate that there's a brake in the sound signal path. Try  using another pair of speakers (or headphones) if it's the same then the problem is in the connector - the metal clamps are bent out of shape. This cannot be fixed, that connector is lost. Plug the speakers in another connector and assign it as the mail one from the Realtek audio Control Panel.
7/8/2010 8:09:40 AM • Evga nForce 680i... • Answered on Jul 08, 2010
Blue screen
Some usb devices are like this. The manufactures simply don't tell you that this can happen.
Your best bet is to boot the PC with the device connected and to shut it down before you unplug it. I know it isn't plug and play but this may be your only choice.
I used to have a phone that did this one in every ten times I connected it.
I would hold my breath each time I plugged it in :)
Hope this helps
9/20/2009 3:20:42 AM • Evga nForce 680i... • Answered on Sep 20, 2009
2answers
Rear audio does not work
Hi the solution for the rear audio do not work is cold solder connection to the mother board or the banana plug female connector. You have to remove the mother board because you don have no access to re solder the the frame cover that area. If the female banana pug connector is the problem the parts is available at radio shack. Before you do all of what I mentioned first you have to confirm by going to control panel click sounds and audio devices and watch the screen and speaker will gray out if the speaker is un plug or not detected. If your PC use Realtek audio device on the control panel click the sound effect manager and click the speaker test tab and perform speaker test. Then if the test fail perform mother board repair. Hope this info might help you solve your PC rear sound problem.
HH
9/5/2009 2:13:31 AM • Evga nForce 680i... • Answered on Sep 05, 2009
2answers
How do i check to make sure what drivers are
Download the correct driver from nvidia, and then use device manager to update the driver. If you have the correct driver installed, device manager will report that the correct driver is installed
9/4/2009 7:56:01 AM • Evga nForce 680i... • Answered on Sep 04, 2009
Evga nForce 680i SLI (122CKNF68) Motherboard Logo
35 questions posted
Top Evga Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Evga Computers & Internet
Most Popular Question
sound problem
  • Computers & Internet
