20 Most Recent
Whirlpool AD65USL / AD65USM Dehumidifier Questions & Answers
Bucket not filling, unit seems to be making more noise
If you are running and not pulling moisture first check air flow. Vacuum the front and back grills and make sure the coils are clean. If you have good air flow the cause of the problem is most like a sealed system issue. This is most commonly a refrigerant (freon) leak. check your use and care manual to find how long the warranty on the system is, sometimes it is as long as 5 years. If it is out of warranty then the repairs are more costly than a new unit.
7/24/2010 1:06:47 PM •
Whirlpool...
Answered
on Jul 24, 2010
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
11/5/2008 8:34:06 PM •
Whirlpool...
Answered
on Nov 05, 2008
My unit runs constantly
unit has a sealed system problem leak in one of the coils, a leak at the compressor, take it to an authorized whirlpool service servicer for a check
9/2/2008 4:21:07 PM •
Whirlpool...
Answered
on Sep 02, 2008
