20 Most Recent
Whirlpool 25.3 cu. ft. / 716 liter Upright Freezer EV250NXKQ Questions & Answers
Dain line frozen
Unplug the power cord and leave the door open for 24 hours to defrost the drain line. You can also take a blow dryer and melt the ice out of the line by aiming the heat towards the frozen drain line and melting the ice within a few min allowing the water to flow again.
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
