20 Most Recent
Samsung HT-E3500 - Home theater system - YouTube - 5.1 - HT-E3500/ZA Questions & Answers
Samsung HT-E3500 region-free
I have a new HT-E3500, and after 20 minutes I got the following to work. The trick seemed to be not holding the repeat key too long. I have a Region B/4, running 080604.01_050708-1_XSA code. I used the R4 code from below. 1) Turn on the player with no disc in the tray Wait till the unit is at the Samsung logo screen. 2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner 3) Now press the REPEAT button on the remote, followed by a five digit code. In this case Repeat 76884 Now it to me about 20 tries to get this to work, It needed to be done without delay. So if you don't get it to work straight away don't loose heart. 4) When it works a 4 will appear in the top left corner 5) Press 9 to make it regionless. 6) Press Eject to OPEN to open the disc tray. 7) Press Eject to CLOSE to close the disc tray. 8) Power the unit off 9) Now power the unit on again, it should now read all regions of DVD Disc. From other threads I got the follow list of region codes. R1 - 29334 R2 - 57538 R3 - 56732 R4 - 76884 R5 - 53814 R6 - 24462
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
