20 Most Recent Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Samsung... | Answered on Jul 14, 2016
If a new set it is somewhere on the back. Check your manual for exact location.
Samsung... | Answered on Feb 15, 2016
If I had a dime for every one of these type of questions I could retire without my pension. The problem with these sets today is that they no longer fall under the category of "durable goods" which include washers, dryers, water heaters, furnaces, etc. They now come under the electronics category. This means that you shouldn't really expect these devices to last much longer than their warranty period. The days of TV sets lasting 10-15 years are over. Three to five is the new norm. They are designed with obsolescence in mind. The manufacturers do not build any tolerances into the electronics so any small power surge or glitch can cause a cascading failure through the device, taking out multiple board with it. You replace one, it works a few minutes, and then it gets blown out by another one that was bad as well. By the time you get through replacing all the boards, if you are lucky enough to get it working again, you find that for a buck or two more you could have bought a new one that was larger and with more features. This is the manufacturer's plan. If TVs lasted 10 years, then they can't keep selling them at the rate they can build them now. If you want one of these to live a little longer than normal, invest the hundred bucks or so into an UPS to attach to it for power and surge suppression. Dollar store surge protectors won't do much to save these touchy devices.
Samsung... | Answered on Nov 22, 2015
This sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Samsung... | Answered on Dec 06, 2014
It sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Check to see if your phone's do not disturb is on. I had a phone that after repeated volume adjustments started turning it on without me realizing it.
Samsung Audio... | Answered on May 17, 2019
Select it as part of the time setting procedure.
Samsung Audio... | Answered on May 08, 2019
The applicable code would be found in a compatible remote control.
Samsung Audio... | Answered on Apr 19, 2019
Looks like there is an AUX IN on the front - you need a cable to run from the headphone socket of your tablet to this input https://www.youtube.com/watch?v=TDEaJfbdKP8
Samsung Audio... | Answered on Apr 15, 2019
how about this mov to avi converter
I saw it was suggested in similar question
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
9 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
when turn tv will automatically turn off
  • Audio Players & Recorders
