20 Most Recent
Fuji FinePix S6500 Digital Camera Questions & Answers
Fineviewer s6500fd
Go on Fuji Uk home page and go on the software updates,(if any) for your camera.
What specifically are you trying to correct?
A smear on the picture
Not easy, with so little to go on, but I try. If it is from left to right complete, could be the sensor (or the connection to the sensor). If it is only partial, it also could be on or in the lens, but that is not very likely.
I think you mean it is on the photo's, and you can or can't see it on the monitor, or is it the other way around? seen on the screen and not on the photo's is something different and not s catastrophic. If really the smear is on the photo, I guess you have to contact your nearest repair centre or buy a new camera.
Card not initialized?
The error can be caused by:1. The xD-Picture Card or internal memory is not formatted.2. The xD-Picture Card contact area is soiled.3. a camera faultfor 1.:Format the xD-Picture Card or internal memory on the camera (p.130)To format the internal memory or xD card goto format in the setup menu and chose the correct memory.for 2.:Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card(p.130).If the message still appears, replace the xD-Picture Cardfor 3.: You won't like this one:Contact your FUJIFILM dealer.
Face Detection Not Working
i foun that on the side (left) of the camara is a dial, turn it to the setting marked s (the middle one) and then try.
Ihave a s6500 it comes up with zoom error can;t
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Focus error on my finefix
Hello
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
replace the camera.
Hope
Regards
Andrea
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
I have the same problem, focus error
well what can one expect after being beaten up with concrete ( grin) You may want to make an insurance claim against the cost of repairs as this is not a DIY fix
