20 Most Recent Amana PTH093E35AXXX Questions & Answers
bad switch, bad motor capacitor, bad motor.
Amana... | Answered on Aug 18, 2015
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Amana Heating &... | Answered on Jun 10, 2019
Check voltage in , there could be one side of breaker burned causing only one side to come through. This happens on older main breakers frequently which messes up whole house.
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana Heating &... | Answered on Jan 20, 2019
Clean the filter and try it again
Amana Heating &... | Answered on Dec 31, 2018
Amana PTH093E35AXXX Logo
1 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
ptac not blowing cold air
  • Heating & Cooling
