20 Most Recent Dometic 3312024.015 Duo Therm Comfort Control 2 CCC2 Champagne Questions & Answers
Furnace fault codes ignition lockout fault.. and
This means the furnace will not operate. Remove the power and then on again to clear it.
12/14/2013 6:34:08 PM • Dometic... • Answered on Dec 14, 2013
Duo therm ac in my rv quit when the converter
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
10/31/2013 8:40:28 PM • Dometic... • Answered on Oct 31, 2013
0answers
Find a manual
Be the first to answer 5/4/2013 3:45:53 AM • Dometic... • Posted on May 04, 2013Be the first to answer
Replacing a duotherm 3105058 thermostat
I was replacing a DUO-Therm 3105058 Rev A. very old Thermostat in a Coachman RV with 3106995.032 from Amazon. After looking all the information on the directions it was clear I would have to play a hit or miss on some of the wiring. Instead of using the same coding, such as RC, RH, G, Yellow and such. they used the function and I had to guess at some.Here is the wiring I found worked:There are 6 wires. One set of two wires (white On the W & red on the RH) and the set of 4 (yellow On the Y, green on the G, red on the RC and blue on the H). So to keep it simple the red on the RH went to the +7.5. The White on the W went to the FUR. HS/HP not used. the Yellow from the Y went on the cool. The green on the G went to the fan. The red on RC went to GND. and the Blue on H went to Hi fan.So red (RH) of the 2 wire goes to +7.5White (W) of the 2 wire goes to FUR.Yellow (Y) to coolGreen (G) to fanOrange or red from the RC lug goes to GNDBlue (H) goes to Hi Fan
12/7/2023 12:23:48 AM • Dometic Heating... • Answered on Dec 07, 2023
3answers
What causes the breaker to trip on a 2006 dura-therm dometic rooftop unit 13,500 BTU
check amp draw either bad compressor or fan motor
10/23/2023 12:10:49 AM • Dometic Heating... • Answered on Oct 23, 2023
Dometic 3107612.008 manual thermostat will cool but not heat.
possible heating element bad
8/31/2022 6:29:12 AM • Dometic Heating... • Answered on Aug 31, 2022
Dometic B2200. Compressor don't stopp
check compressor relay possible stuck on
8/19/2022 3:58:09 AM • Dometic Heating... • Answered on Aug 19, 2022
Dometic duo-therm 15K BTU 630516.331; compressor does not start, but the fans work in both high and low speeds
make sure thermostat on auto possible start up capacitor on compressor
8/6/2022 5:12:30 AM • Dometic Heating... • Answered on Aug 06, 2022
Dometic B3000 Air Con has no power to it.
if power to unit and thermostat is calling for action then check start up capacitors
3/6/2022 6:52:34 AM • Dometic Heating... • Answered on Mar 06, 2022
2answers
3answers
Awning retracts at random
some awnings have a sensor that retracts the awning if wind elevates to certain level. i wish mine did. i have seen them ripped off rv's.
2/6/2022 7:13:10 AM • Dometic Heating... • Answered on Feb 06, 2022
My dometic air conditioner on my Jayco Silverline 2018 caravan won't turn on unless it is in ventilation mode
no info -look in your paperwork for your trailer unit and the mystery a/c unit and look up the trouble code in owners manual --notify jayco of problem --do online search of a/c using make and model for trouble shooting guide - rv shop
9/2/2021 12:41:20 AM • Dometic Heating... • Answered on Sep 02, 2021
I need an electrical wiring diagram for an rv air conditioner. Dometic model QC135-A.
So original was ecm and you’re installing psc?? All low voltage speeds will go away and you just need to break the new, high voltage speeds, with a relay. Hope that helpsI can’t find info on the 135a. Does it have a control board to land wired to?? What model motor???Can’t make out the original wiring diagram. The white is your common or neutral. The different speeds are for constant fan speed, cooling speed, and heating speed, this is your hot. Not sure if you have a control board in your unit but if you do it will say “common/ fan/ cool/ heat/ park for places to land your wires. The browns go to capacitor and the orange and purples would get swapped if it were running backwards. ( meaning blowing air out of filter rather than pulling air through filter. Zip tie loose wires to prevent getting caught by wheel.
7/15/2021 10:51:15 AM • Dometic Heating... • Answered on Jul 15, 2021
Need advice wiring new motor into old Dometic a/c unit.
On a single phase universal motor with a start and a run capacitor, that is handy. The start capacitor is fully automatic as there is an internal centrifugal contact that breaks the contact when the motor reaches near running speed. The run capacitor puts one of the motor windings out of phase with the other and determines the direction. Placing the run capacitor on the neutral will make the motor go the other way than on the live.
7/14/2021 7:03:43 PM • Dometic Heating... • Answered on Jul 14, 2021
Dometic 3312024.015 Duo Therm Comfort Control 2 CCC2 Champagne Logo
10 questions posted
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Heating & Cooling
Most Popular Question
duo therm unit model no 59516 331 fan
  • Heating & Cooling
