20 Most Recent
Dometic 3109228.001 Duo Therm Comfort Control 5 Button Questions & Answers
No display
takes 12 volts d.c to work.
8/23/2015 10:15:03 AM •
Dometic...
Answered
on Aug 23, 2015
Flashing code ee
sounds like defective t-stat or it needs to have time and setpoints reconfigured
8/20/2015 10:40:00 AM •
Dometic...
Answered
on Aug 20, 2015
Error code E2
open circuit or out of range indoor temperture sensor. locks out cool and heat.
8/16/2015 8:43:40 PM •
Dometic...
Answered
on Aug 16, 2015
Replacing a duotherm 3105058 thermostat
I was replacing a DUO-Therm 3105058 Rev A. very old Thermostat in a Coachman RV with 3106995.032 from Amazon. After looking all the information on the directions it was clear I would have to play a hit or miss on some of the wiring. Instead of using the same coding, such as RC, RH, G, Yellow and such. they used the function and I had to guess at some.Here is the wiring I found worked:There are 6 wires. One set of two wires (white On the W & red on the RH) and the set of 4 (yellow On the Y, green on the G, red on the RC and blue on the H). So to keep it simple the red on the RH went to the +7.5. The White on the W went to the FUR. HS/HP not used. the Yellow from the Y went on the cool. The green on the G went to the fan. The red on RC went to GND. and the Blue on H went to Hi fan.So red (RH) of the 2 wire goes to +7.5White (W) of the 2 wire goes to FUR.Yellow (Y) to coolGreen (G) to fanOrange or red from the RC lug goes to GNDBlue (H) goes to Hi Fan
