20 Most Recent
2002-2008 X-Type Headrest Back Cushion Questions & Answers
Jag xtype engine failure
when you said stop suddenly,what exactly do you mean? There was not any warning light light on? or any strange sound? The engine does not turn on at all like a seized engine? if so check for any signs of engine oil level whether you do have any oil in the engine sump. if there is not any sign of oil then the engine seized. For the engine oil to disappear means that either you did many miles overdue to change or your engine was burning oil,without you notice it. Ask your mechanic to do his mechanical check.
My dash lights dont work
Check your fuses. Also check the control knob for your headlights. If you turn the knob, it usually controls the dash lights.
Turn off passenger airbag
Ahhh, you have the notorious Jaguar always-on passenger airbag light, too - eh?
So do I. I "fixed" mine by covering the light with a spot of black tape.
Go to
http://www.jaguarforums.com/forum/ and search for the problem in the specific sub-forum to your car.
That one is usually related to a bad ground to the passenger seat, or a loose wire under the seat, but it can be a myriad of things. You will find ideas and answers at the forum website if you search.
Just reach up under the seat and start wiggling any and all the wires you find. More often than not, that will fixya!
The Jaguar dealership will charge you an arm, a leg, and your first-born to effect the repair if it is not under warranty or recall. The folks at the Jaguar forum will charge you nothing to diagnose your problem and tell you how to fix it yourself, and do a better job.
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
- Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
- Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
- Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
- Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
- Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
- Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
