20 Most Recent Amana In Wall Install Kit For Digismart Ptac Units - Wall Sleeve, And Grill Questions & Answers
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Amana In Wall... | Answered on Nov 19, 2014
There should be a fan symbol on your remote control. In the "mode" control, there should be the following options.. Heat, cool, Auto and fan. If you select fan, only the fan will run. No heating or cooling.
Amana Heating &... | Answered on Jun 10, 2019
Check voltage in , there could be one side of breaker burned causing only one side to come through. This happens on older main breakers frequently which messes up whole house.
How are you determining that one section.is cold and one warm? If this is in fact the case you have a blockage in the coil or a compressor that is down provided this is a multi compressor unit.
Amana Heating &... | Answered on Feb 06, 2019
I'm leaning 2 directions, one is that your tstat is sensing your heatpump can not keep up with the load. Therefore bringing on heat strips or two, you have a cycles per hour limit set for compressor heating and your machine is cycling too often.
Amana Heating &... | Answered on Jan 27, 2019
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Amana Heating &... | Answered on Jan 20, 2019
Clean the filter and try it again
Amana Heating &... | Answered on Dec 31, 2018
I would guess two possible problems - dirty thermostat contacts and many appliances are also fitted with a thermal fuse or other type of thermal cutout which might have failed.
Amana Heating &... | Answered on Dec 13, 2018
Amana In Wall Install Kit For Digismart Ptac Units - Wall Sleeve, And Grill Logo
1 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana ptac not heating code np
  • Heating & Cooling
