20 Most Recent
Coleman 805D712T Questions & Answers
Glass top broken
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=1600
you can find that here
How to take care of
http://www.colemanspas.com/content/show/24/ this site will help you its the coleman maint and questions of how to take care of it
Coleman a/c
black= power wire - red= power wire+ blue= a/c control orange#1= thermo orange#2= common
Need switch for colman a/c unit
jason, if you are willing to to a little wire tracing, you can do this! We're going to create a new switch function. Chances are that two of the wires are probably for the fan motor (high and low). I'm not sure about max and normal. This uses a two position switch. Figure out which wires go where...then...get a '3 way' switch from the hardware store (they contain a common and two 'poles') along with a plastic box to contain them, a double switch cover and some 'heavy duty zip cord'. This is lamp cord but a heavier grade called number 16 or number 14 (14 preferred). Extend each of the wires and tape the connections. Now, threading the wires into the power box, hook the two fan wires that come to the switch to the new switch. Now, the common terminals and the power supply wire (probably the black) should be hooked together. It should all work...ugly but functional. If you need an on/off switch, you can make that a three gang box and include a standard on/off switch. If you can figure out the max/normal function, you can either switch it on or off or either/or...depending on the switch function. Hope this helps.
Coffee pot top
as far as i can tell you cant just buy a lid, mabe on ebay instead of buying a whole new pot or call customer care at 1-800-835-3278.
Let them know you just need a replacement see what they say. Heres the item number for it on ebay, only one day left at $16.99 200133333009 , and heres the link
http://cgi.ebay.com/New-Coleman-Stainless-Steel-12-Cup-Coffee-Pot-805D712T_W0QQitemZ200133333009QQihZ010QQcategoryZ87143QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
What if i dream about i'm going to be married??
One things for sure many repairs I have carried out over the years I have been married to the them as to dreams,I am sure for many Dreams do come true...Take it easy with the coffee though....
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
