20 Most Recent
Lancaster Colony Deluxe Coffee Urn 58 Cup Questions & Answers
Looking for percolator tube for 90 cup urn
Hey, sorry I don't have a solution, but a question! Do you still have the manual?? I have the same maker and woudl like some advice on making 90 cups of coffee before I have caffeine deprived angry guests on my hands.
WE HAVE OLDER LANDCASTER 90
Hi, am sure that all it needs is to be cleaned. Gently take it apart, clean the parts, use a soft brush if needed and put it back together and if it still leaks, it is advisable to replace it....
Hello! I need a stem
Hello. Go directly to the manufacturer at these contacts:
Lancaster Colony Commercial Products Inc.
P.O. Box 630
Columbus, Ohio 43216
Toll Free 800/292-7260
Canada 800/528-2278
614/263-2850
FAX 614/263-2857
www.lccpinc.com
[email protected]
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
