20 Most Recent
Holmes Products HCH4953-U Ceramic Compact Heater Questions & Answers
When temp. is set it will not come on at set temp.
The temp setting is not an "exact science" and is conditional:
The unit may be too close to a wall or other obstruction, such as an enclosure. It must be able to sense the temperature in the general area. When you move it, give it a few minutes the first time. After that, it will work correctly.
"Screw Stud Melted After Faulty Power Cord Occured".
Hello LILSHAUNLSS5,
I am not sure I understand the description of the problem but let me take a shot at helping you. First off, you obviusly had a short of some sort that drew excessive current , causing a fault and ultimately got hot enough while drawing that excess current to melt something.. Here is where I am a bit confused. Power going to the heater elements comes off the thermostat and onto one side of your elements. If that is where the screw melted, can you remove th eoriginal screw and redrill and tap a new hole for a new screw to be used? If there is any question about the integrity of that termination then I wouldn't mess around with it since anything you do wrong , may result in a fire. So whatever you decide, be careful. If you can provide a picture or sketch of what it is that failed, I may be able to assist you further.
Good Luck,
Regards,
Rick
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
My oil filled heater is making a buzzing noise every 15 minutes or so what wrong with it?
Probably the thermostat contacts have become worn and a certain amount of arcing is happening when they close.
Replacement thermostat units used to be easy to change and were readily available for quality domestically manufactured oil filled radiators but these days it would probably be cheaper to buy an imported heater. You wouldn't lose by asking your local supplier and if they are still available check the internet price.
It would be wise to check the wiring and internal connections before junking it.
