20 Most Recent
Shure Beta 58 Microphone Questions & Answers
Shure slx2 no transmit audio
You can try changing out the cartridge to see if that helps. Otherwise, something in the mic is broke and needs repaired. I'd send it to Shure to have a professional fix it.
Where is the mute button on shire beta 58a
I assume you are asking about a wired Beta 58A. The Beta 58A is not offered with a switch. Audio Engineers do not like switches on microphones as the talent could accidentally switch off the microphone.
Shure 58 when plug it has no sound
First i would check the cable. If cable seems good I would buy some contact cleaner and try cleaning the xlr pins on the bottom of the mic. Last i would take the set screw out of the side of the mic and carefully remove the xlr assembly. There are 2 wires connected to that and not a whole lot of slack so be careful. Basically make sure they are still soldered on.
Shure buzz
check the lead connecting the receiver to system by replacing it out. Check that the correct power supply is still being used.
SHURE BLX4R BATTERY LIGHT OFF AND WONT SYNC - HELP!
please attempt to factory reset your microphone. Also, some companies only allow certain accessories like a battery to be provided by them or special partner companies. So, please verify with your manufacturer that duracell batteries are allowed to be used within their products.
Thank you.
How do you turn off mute icon on nady uhf-800 wireless systems?
This system is out of date and actually ******* to use sell (NOS or old) or in the US these days as the govt. sold off those wireless frequencies to the cell phone companies. The mute icon is likely always on because as soon as you power it up the cellco transmitters are overpowering the miniscule 20 milliwatts your system puts out. Sell it legally on ebay mexico or europe where those frequencies are still in use for wireless mics.
Interference on psm200 wireless monitor
- Because the US govt. has sold off those frequencies to Sprint/ATT/Verizon and that is the interference you are hearing. It is now ******* to use those systems, as they interfere with cellular systems. I wouldn't buy another wireless system for a year or so, as the govt. has just done this AGAIN and audio pros will now again be buying new wireless systems replaced just years ago because of the govt's need for money and cell co's need for bandwidth.
- Next time, step up and buy a tuneable system that will allow you to scan for open frequencies to use so you can avoid stepping on/being stepped on by someone else using the same frequency but with much more power than the 20 mw a PSM 200 puts out.
- You cannot legally sell this system (new or used) in the US today. To unload it, sell it on eBay Mexico or europe, where these frequencies are still in use and legal.
