20 Most Recent Whirlpool WED6400S Electric Dryer Questions & Answers
WED6400 BEEPING LOUDLY
If it is working ok in timed dry it would have to be something in the auto cycle maybe the sensor or wiring or last resort the timer sounds like the timer might have a bad connection inside the timer. Hope this helps good luck
8/15/2018 3:59:04 AM • Whirlpool... • Answered on Aug 15, 2018
0answers
Wed6400sw1
Be the first to answer 5/12/2013 6:48:01 PM • Whirlpool... • Posted on May 12, 2013Be the first to answer
I have ordered a door latch assembly for my cabrio
open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
latch assembly:
http://cgi.ebay.com/Dryer-Door-Latch-Catch-279570-fits-Whirlpool-/330503664154?pt=LH_DefaultDomain_0&hash=item4cf38db21a
2/28/2013 4:57:20 AM • Whirlpool... • Answered on Feb 28, 2013
Dryer has power...nothing electronic gets power
Remove the rear panel and check the dryers thermal limiter fuse, it may be blown due to dirt and lint build up in the cabinet or a shorted heating element or both..
7/16/2012 11:25:11 PM • Whirlpool... • Answered on Jul 16, 2012
0answers
Trying to replace heating element
Black wire goes on the top prong and the white wire goes on the bottom prong.
7/14/2011 9:52:12 PM • Whirlpool... • Answered on Jul 14, 2011
Have a whirlpool electric dryer.
Usually, lint has found it's way into the burner chamber. This is often evidenced by small brown spots on clothes. To resolve, unplug the machine and open it up and investigate the burner area.
When finished cleaning, remove the outlet hose, turn on the unit and form an opinion about air flow.....Hook hose back up, turn machine on, and go outside the building, and verify very similar air flow volume. Any restriction will slow drying and allow more lint to get drawn into the air inlet.....
3/21/2011 5:46:55 PM • Whirlpool... • Answered on Mar 21, 2011
It will power on but will not tumble it will not
Hi
I believe the control is fine rather it is the thermal fuse located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if there is no continuity then replace it as it cannot be reset. Hope this helps...please post back for further assistance.
Daniel
2/13/2011 5:32:15 PM • Whirlpool... • Answered on Feb 13, 2011
0answers
Squeaky on start up
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
12/25/2010 4:21:24 AM • Whirlpool... • Answered on Dec 25, 2010
My dryer powers on but it does not spin or heat.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
12/19/2010 4:20:49 AM • Whirlpool... • Answered on Dec 19, 2010
Dryer lights come on on
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
11/28/2010 12:54:08 AM • Whirlpool... • Answered on Nov 28, 2010
Whirlpool steam duet dryer won't start at times
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&#&&
9/30/2010 7:41:24 AM • Whirlpool... • Answered on Sep 30, 2010
The damp light stays on on my whirlpool duet
It appears your humidity sensor has failed in this instance.
9/30/2010 6:59:12 AM • Whirlpool... • Answered on Sep 30, 2010
My control keys are locked
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
5/16/2010 2:39:26 PM • Whirlpool... • Answered on May 16, 2010
Whirlpool WED6400S Electric Dryer Logo
Popular Tags
48 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
  • Dryers
